Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-20-2011, 07:53 AM
isasuleahmed is on a distinguished road
Laser engraver Emitting Ray from the tube.
I got this Laser Engraver for INK EXPRESS (HK) in 2005. It's 1280x900 80 watts since then I have been buying my accessories from WEIKE LASER JINAN - Tina is my sales rep.
Last week after working for 10 hours, I left the laser on for 6 hours (which I never did). When I came back I noticed that the laser Tube is continuously emitting ray - similar to the ray you see when you use OPEN-LASER command. I turned the laser off. Since then, if I turn on the laser, the tube will start emitting ray.
My effort so far:
1. I have disconnected the keypad cable - no solution
2. I check the power supply - no visible burnt on it
3. I try a new laser tube - no solution.
Please, I need help - workshop is idle!
Isasuleahmed
Old 12-20-2011, 07:33 PM
wktina is on a distinguished road
Smile
dear,
why not write me email but only waitting for help here.you mean when you press laser,the laser will emit continuously without stop? if so there maybe some static interrupt. and if you modify any setting in LCD? there's one laser setting,the laser time should be 0.
anyway,you also pls write me email to tina@wklaser.com
we will help you solve this problem
Old 12-20-2011, 10:09 PM
Rodney Gold is on a distinguished road
Check your grounds , you really need a spike driven in the earth and to take all grounds from the various components in the laser to this ground.
Old 12-21-2011, 05:47 AM
Thanks, Rodney.
I will check.
Laser 150 W RECI laser tube, monster!!!! lamicron Laser Engraving & Cutting Machines 17 11-09-2011 09:11 PM
wklaser (Gweike laser) 2011 No. 1 Hot Product--6040N laser engraver display Melody-gweike Laser Engraving & Cutting Machines 0 10-06-2011 03:57 AM
Problem- Laser tube emitting continuous beam jeaves Laser Engraving & Cutting Machines 4 10-03-2011 02:02 PM
New Machine Build- We supply you CO2 laser machine also laser tube masterandroger Laser Engraving & Cutting Machines 0 12-23-2010 09:41 PM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
