| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
hello we have a 60w co2 laser made in china and just today the tube was damaged. I want to know from recomandation if i can upgrade from 60w to 150w . I have a bughet of 1000 euros for the tube and supply . I tink its needed to change the mirrors and the laser head if you go to 150w Best regards Andrei |
| You just need to fit the tube and its power supply , if your mirrors and lenses coped with 60w , they should do fine with 130w or so. You might not be able to fit the tube in the machine so might have to cut away part of cabinet and do other modifications so that the tube output sits in more or less the same place your 60w one did |
| Reci in Beijing Beijing Reci Laser Technology Co., Ltd. You might consider getting their mirrors and a ZnSE lens as well , if you have real cheap and nasty ones |
| You will need new laser tube, new laser power, holder for tube, extension fan. And if your lens for 60W is of 50, you should change the lens to 63.5 or 100. 60W is suitable for engraving, while 150W is for cutting. If you upgrad to 150W, it is not suitable for engraving any more. And a 150W laser tube is of 1850mm long. If your machine is a small one, that'll be a little funny with such a long tube. You can write to me: li@wklaser.com, if you need any help |
Which power is good for both cutting and engraving? |
| If you want both best result, you can try 150W & 60W dual heads machine. |
#11
Once we bought piece of sh...t called EXLASE laser machine with RECI 80 laser. This laser started from 22% of it power. We had to trash it. RECI told us they are not interested to resolve laser problem cos it was OEM for EXLAS. EXLAS said it is OK. It is normal. So we will NEVER buy RECI or or EXLASE.
__________________ CNC lasers, constructions, service |
| Newbie- tube endforming equipment for telescoping tube | DanP | Want To Buy...Need help! | 2 | 01-23-2012 04:32 AM |
| You Tube | M250cnc | Test Forum | 5 | 04-07-2010 10:20 AM |
| Newbie- Tube cutting; tin slots and tube ends | marineboy | CNC Plasma and Waterjet Machines | 0 | 10-13-2009 04:03 PM |
| Problem- Upgrade from 60W to 80W laser tube | bibi | Laser Engraving & Cutting Machines | 4 | 10-28-2008 02:56 PM |
| Is this a bad tube? | FlyGuy007 | Laser Engraving & Cutting Machines | 6 | 06-13-2007 05:44 AM |
