| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi. This is my one of three threads I will start after my very first attempt to laser engrave photos on wood. I am using JC-4040 from China with a Photoshop bmp opened in Moshidraw for the output. Amp meter set to 0.8. A 6cm by 8cm photograph took approximately 25 minutes to complete. The specs of the machine state the engraving speed is < 300mm/s. Vendor told me it would take about 35 seconds to engrave a photo on wood. Am I doing something wrong or is this what I should expect? Thanks. |
| It seems it can be quicker with the right image conversion and output settings. Unfortunately I have to use MoshiDraw as it is the only software my machine will recognise. MoshiDraw is without doubt the worst software I have ever used in my life. I have uploaded an image of the output settings. Can anyone suggest what settings would be the quickest output to laser engrave on to wood? |
| Hi there as I have used the moshi draw I used for speed settings around 35 in both greetings walt
| JC-4040 - Smudging photo | 4040 | Laser Engraving & Cutting Machines | 7 | 01-21-2012 04:14 AM |
| Build Thread- Super-PID speed controller installation to Fixed speed Router | Khalid | DIY-CNC Router Table Machines | 14 | 11-13-2010 04:29 AM |
| Need Help!- Fanuc O-TD-controlled lathe machine at low speed and fixed speed problem. | bursa017 | Fanuc | 0 | 06-11-2010 01:59 AM |
| Cutting speed locked to Z torch height control speed | Beefy | Mach Plasma / Laser | 1 | 02-14-2010 05:14 PM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
