Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-10-2011, 07:24 AM
AH11 is on a distinguished road
Cutting 1/32" thick mirrors using a CO2 laser
Hello,
I am new to this forum. I am using a compact CNC router that has a carbide wheel to cut thin sheets of mirror (1/32" thick with silver backing) into small geometrical shapes (triangles and trapezoids). I am having lots of problems with the machine (mechanical and lack of precision). I am thinking of buying a CO2 50W laser engraver. I am wondering if with some particular settings I would be able to etch the glass side of the mirror so it can be cut into the desired pieces without chipping the edges (with decent precision like within 1/32" and good speed). The pieces are like 1/4" to 2" in length on any one side. Any suggestions would be greatly appreciated.
Old 12-10-2011, 09:11 AM
Tweakie's Avatar
Tweakie is on a distinguished road
A CO2 laser of 50Watts can only produce a series of micro-fractures into the surface of the glass. It will not cut the glass nor will it be able to make a suitable scribe line for breaking the glass.
Have you tried a wheel type glass cutter, swivel mounted in your CNC then breaking the glass along the scribe lines ??
Tweakie.
CNC is only limited by our imagination.
Old 12-10-2011, 06:33 PM
Hello Tweakie,
Thanks for your response. I am already using a small custom-made carbide cutter connected to a cnc router. I am having lots of issues with the machine so I thought about switching to laser. I have read in some places that the CO2 laser when tweaked with the correct settings can actually cut glass/mirror well enough. Considering that the mirror I am using is 1/32" thick, I assumed that it could cut deep enough for me to get a nice cut. The issue is that I am using it to cut small pieces that need to have precision and I am not sure how well a laser would do that on the mirror.
Old 12-10-2011, 06:45 PM
underthetire is on a distinguished road
Think your going to need a lot more power than a small 50 watt. I'm guessing more like 400 watt+ to cut glass. Glass can and will dissipate the laser beam, just like white foam board will.
Old 12-10-2011, 10:46 PM
Rodney Gold is on a distinguished road
Use acrylic mirror and you can cut with 10 watts. It comes in 1mm thicknesses (1/25")
Old 12-15-2011, 01:28 PM
TLHarrell is on a distinguished road
Most companies who cut pieces of mirror would be using some sort of diamond wheel saw. This leaves a smoother edge. The laser won't make a dent. And scoring and snapping leaves nasty sharp edges which require finishing.
Tags
co2, cut, etch, laser, mirror
RFQ: CNC/Laser Cutting 0.04" Thick PC (Provided) LaserTagging RFQ (Request for Quote). 0 07-29-2011 03:59 PM
RFQ - Aluminum 0.090" thick fins, Water or Laser cut jhuebbe RFQ (Request for Quote). 0 05-14-2011 01:51 PM
Need Help!- Laser or Water Jet 316ss, 304ss, 303ss, sheet metal 0.090" thick (9" x 9" footprint) twp CNC Plasma and Waterjet Machines 1 01-13-2011 09:43 PM
Laser cutting 0.020 in thick stainless steel 78-bandit Laser Engraving & Cutting Machines 5 06-12-2010 10:37 AM
cutting 1/4" thick carbon fibre acidcustom Composites, Exotic Metals etc 2 05-24-2007 12:29 AM
