Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-25-2011, 02:45 AM
Freddie1 is on a distinguished road
Need help with chinese laser
Hi
I am new to this forum as well as laser cutters.
I just received my JC6040 80W laser from China but cant get it to work.
If I try to cut something I can hear a noise at the tube but it does not cut.
My waterpump is working fine so it is not a water problem.
Is there a way to test if the power supply and tube is OK.
Regards
Freddie
Old 11-25-2011, 03:16 AM
Nubbly5 is on a distinguished road
Good luck Freddie
We have had a real struggle getting ours to work and found that the company we purchased from were BUGGER ALL help.
Hoping someone here can help you out.
Old 11-25-2011, 03:31 AM
Smile
Hope you can help me because seller is no help at all.
Freddie
Old 11-29-2011, 02:28 AM
kofi_sunic is on a distinguished road
Is there a laser came out from the focus lens?
Once you turn on the laser and press "test", did you find a pink line inside the tube?
Old 11-30-2011, 05:08 AM
amy_stars is on a distinguished road
Laser repairs/ chinese laser
When I bought my laser I was going to get one from china but found a company near by that sold them. I spoke to them and they said they repair a lot of lasers from china. They are called HPC laser, have a look at their site they might be able to help.
Amy
Old 11-30-2011, 08:05 PM
Gold Member
Ken_Shea is on a distinguished road
You need to have the power set to no less then 15%, I'd try 20%.
What is the power set to at the key pad?
Under laser set what is the milliseconds set to?
You should see a purple/pink laser at the center of the tube when it is fired.
Ken
Old 12-01-2011, 12:32 AM
Melody-gweike's Avatar
Melody-gweike is on a distinguished road
Hi Freddie,
Have you succesfully set up the laser? You need to check that. Sometimes customers didn't equipped the laser tube correctly, so the laser tube didn't work. If you did as the right way, maybe there were some quality problems with the laser tubes.
I have uploaded a video of how to set up the laser and i have sent the link to this forum before. You can click below to watch
http://www.tudou.com/programs/view/MzazGBoZ8fs/
Is your 80W laser tube of Reci Brand? If so, the laser tube can have the warrenty time for 10 months. You can contact your seller to change a new laser tube for you if there is quality problems.
Hope you good luck!
Old 12-01-2011, 10:08 PM
TLHarrell is on a distinguished road
A high pitched whine will indicate the tube is getting power to fire. Like others have stated, there should be a pinkish/purple glow along the tube. This is the plasma created by the high voltage in the tube.
Place a piece of paper over the "business end" of the laser and hit the test button. If it burns a neat little hole in the paper, tube's firing.
Next move to the first mirror with the paper and repeat. Is the laser hitting the first mirror? Try the second mirror (the one mounted on the gantry). Then try the one at the laser head. I'm thinking your adjustment is hosed and the laser is flying off somewhere outside of the normal beam path. If it's misaligned, it won't make it to the head. Work through that and see how things go.
Old 12-03-2011, 01:45 AM
Smile
Hi
Thank you for all you advice. I tried everything but all I hear is a crackling noise at the tube but no pink light.
I have tried also with a paper at the tube but nothing is happening.
I will I know if the power supply is giving enough power?
Freddie
Old 12-03-2011, 06:29 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Originally Posted by Freddie1 View Post
Hi
Freddie
Sorry to say this Freddie but the crackling sound at the tube usually indicates that the tube is dead. You should, I think, plan on getting a replacement tube.
Tweakie.
CNC is only limited by our imagination.
  #11   Ban this user!
Old 12-05-2011, 09:38 PM
coase is on a distinguished road
Hi Freddie,
Maybe something wrong of the laser tube, it is good for your to upload some photoes of your laser.
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 13 05-02-2012 02:43 AM
Newbie- should we buy this chinese laser ?? albo Laser Engraving & Cutting Machines 41 06-27-2011 01:21 AM
Where to buy a Chinese 80W Laser PaioX Laser Engraving & Cutting Machines 25 09-17-2010 02:57 AM
Newbie- Chinese laser Gary123xyz Laser Engraving & Cutting Machines 35 07-25-2010 02:00 PM
Chinese Laser FMA1 Laser Engraving & Cutting Machines 3 03-19-2008 06:38 AM
