Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-19-2011, 06:26 PM
Bekir_SA is on a distinguished road
I need help with Laser Engraving Machine DC-K40 (no fire in the pipe)
Hello.
I am from Bosnia. City of Sarajevo, My name is Bekir.
I hope you will help me succeed...
I bought the Laser Engraving Machine DC-K40 through eBay.
I have a problem, the fire in the pipe does not appear
I controlled the fuse for the power - OK
connect to ground - OK
water circulating in pipes - OK
Cleaned all mirrors - OK
Water temperature - OK
But even after all this, there is no fire in the pipe ...
When I send the machine to do something, the machine works, but no fire ...
When I click the test button on the laser machine, no fire ...
I enforced a laser intensity on the machine but nothing ...
just no fire in the pipe ...
I need help, the two months I am trying to solve the problem but nothing.
makes me crazy ...
This is the machine:
Laser Engraving/Cutting Machine (DC-K40) - China Stamping, Stamping Part, Automatic Stamping in Cutting & Fold-bend Machine
Forgive me for my English ...
If it is bad ...
Thank you ...
Old 11-20-2011, 01:17 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Have you checked the safety switch for the top cover is operating OK ??
and do you have a flow switch for the water and is this OK ??
Tweakie.
CNC is only limited by our imagination.
Old 11-20-2011, 02:09 AM
cinematic2 is on a distinguished road
99% this machine does not have top cover safety switch nor flow switch.
CNC lasers, constructions, service
Old 11-20-2011, 03:31 AM
Tweakie's Avatar
Rules that out then.
Tweakie.
Old 11-20-2011, 07:51 AM
Gadroc is on a distinguished road
K-40s do have a "safety switch" of sorts on the top. They have two red buttons one labeled Laser Switch and one labeld Test Switch. The Laser Switch must be in the "in" or "on" position for the laser to fire.
In my K-40 that switch was wired to the water protection input on the power supply so that when it was pressed in it connected the water protection to ground or other wises left it unconnected.
Old 11-20-2011, 04:37 PM
All the buttons that need to be involved are involved.
But there is simply no light in the tube ...
The only thing I have not examined, the wiring from the power supply to the tube ...
I Capture the board today to see some light glows green, some red ...
I do not know she should be all green?
Old 11-21-2011, 08:52 AM
There is picture:
Old 11-21-2011, 09:25 AM
If you think the laser is firing it could be your mirrors off alignment. The means at some point the beam is missing the next mirror which would result in nothing happening at the head where your expecting it.
Check out the alignment tutorials online for help with that. Be careful and wear eye protection especially if they are that far out of alignment where you don't know where the beam is going.
Old 11-22-2011, 04:14 AM
I set up a mirror, using a handheld laser pointer ...
I tell you, two months I have been fighting this machine, but no progress ...
Old 11-24-2011, 02:17 AM
This is what Red Point (Red Dot) is for.
If you have a real Red Point you wouldn`t have to fight with handheld laser pointer and you would have alignment set 100% perfect.
  #11   Ban this user!
Old 11-24-2011, 03:12 AM
Tweakie's Avatar
Hi Cinematic2,
Could you please give some more details of the real Red Point (pic would be good) and how you would use it for alignment please.
Thanks,
Tweakie.
  #12   Ban this user!
Old 11-24-2011, 05:25 AM
Just like that.
This is my one of my machines real picture.
Smoke is to visualize red beam that is normally invisible in the air.
sell laser engraving and cutting machine, laser marking machine lindagstar Trade Shows and Events 4 08-27-2011 05:39 AM
Need Help!- CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser vksingh Laser Engraving & Cutting Machines 2 07-01-2011 10:52 PM
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
Supply Laser cutting machine and Laser engraving machine sherryguo Product Announcements & Manufacturer News 5 11-27-2007 07:47 AM
