Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-09-2011, 05:56 AM
ho-229 is on a distinguished road
Servo tuning
5.2.2. The tuning is very much motor/machine/encoder dependant. There is no universal procedure. Before you start to tune drive you should mechanically disconnect motor from the machine and you should have the E-stop switch very close to your hand. An incorrectly tuned drive can violently oscillate which can do mechanical damage to the machine/motor or overheat the drive. It is also a good idea to start the tuning at a lower voltage (if you can drop down the voltage) to familiarize yourself with tuning. There is much less mechanical/electrical energy.
I have Panasonic servos displaying the aforementioned oscillatory characteristics at rest; I am curious what PC based software if any can be used to tune/correct these deficiencies?
Thank you in advance
Old 11-11-2011, 06:51 AM
Hmmm...
Old 11-11-2011, 09:06 AM
keebler303 is on a distinguished road
What drive are you using? How old? Does it have any connection to a computer? How do you adjust the tuning parameters?
I have used Allen Bradley and Baldor servo drives. Both come with a free software used to autotune the servos. It has worked well for me on a variety of motor sizes and makes.
Matt
Servo Tuning HELP!! Julian M Servo Motors and Drives 1 07-17-2010 07:06 PM
Servo tuning bmlw Daewoo/Doosan 2 05-13-2010 08:57 AM
VF-2 servo tuning Rstewart Haas Mills 0 10-28-2009 01:59 PM
Problem- 6t Servo tuning? Jerry Shorter Fanuc 5 08-17-2009 05:28 PM
appropriate servo tuning.... help? howling60 Servo Motors and Drives 6 02-27-2006 08:48 AM
