Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 11-09-2011, 01:35 AM
urbanstein is on a distinguished road
Can 25watt cut through 3/16" acrylic and/or wood?
Hello,
I am looking to buy a laser cut machine to start an etsy shop. Can 25watt machine cut through 3/16" acrylic and/or wood?
What would be a ideal price to pay for a used 25 watt VersaLaser VL 200?
Thank you!
-christine
Old 11-09-2011, 02:44 AM
Paulette is on a distinguished road
I suggest you MORNTECH hot sale laser engraving machine,,This machine can do what ever you want to do.
MT3050DII is the updated small laser engraving machine .With more function and fulfiled for all detailed engraving works.
USB port connect ,software support Win7 /Corel X5.
Newest mainboard ,more functions.support cylinder materials engraving work.
Electrip up and down worktable ,automatic focus function; red dot function.
Best quality co2 laser tube 45-50w.
with air pump;water pump;exhaust fan.
If you are interested in it,you can go and see.
http://www.morntech.com/: Laser engraving machine , CNC router
Old 11-09-2011, 11:49 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Christine,
Yes 25W will cut through 3/16" clear acrylic albeit rather slowly. It is doubtful if it would cut 3/16" wood without multipass, which makes a very poor cut most of the time but, to a large extent, it depends on the type of wood.
Probably best to look for 40Watt minimum.
Tweakie.
CNC is only limited by our imagination.
Old 11-10-2011, 07:02 PM
wshappy's Avatar
wshappy is on a distinguished road
25W is too samll, 50W is much suitable for you, 50W laser power could cut acrylic max reach to 6mm, MDF 2mm, usual wood about 5mm, for rubber about 2mm, so the laser engraver match with 50W laser power is much more suitable for you.
Old 11-13-2011, 08:21 PM
Hurricane21 is on a distinguished road
We can help
Christine,
Please check out our 40W - 16x12 co2 laser. Category 1 Agnes - 40W Desktop Laser - Lasers - Products
We also have these on sale for $2995. and we are based here in the US with offices in Florida and Nevada.
We can be reached at 866-475-1062 or sales@hurricanelasers.com
Thank you and we look forward to helping you.
The Hurricane Laser Team
Tags
25 watt, universal, versalaser
RFQ: 1/2" Interior signage letters - metal, acrylic, or even wood, depending on cost nventian RFQ (Request for Quote). 1 05-14-2012 06:43 AM
What causes "rough" edges when laser cutting acrylic? shobley Laser Engraving & Cutting Machines 3 04-28-2011 06:19 AM
Need A Quote- Small batch of Acrylic 80mm-diameter "rings" needed theorie Employment Opportunity 8 03-02-2011 02:47 PM
Newbie- Advantages of Acrylic vs Wood vs Aluminum for the gantry? (1st build) pswayze DIY-CNC Router Table Machines 10 11-05-2009 04:39 AM
Problem- Cutting Acrylic on a Wood Router deanbrock WoodWorking 24 02-13-2008 05:39 PM
