| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Engraving machine common faults are: 1, the spindle motor short circuit, bad bearings, broken rotor, rotor slip wire, etc. 2, limit switches and limit switches lines perishable 3, Z-axis 608 is easy to bad , 4,Pump easy to ring or no water 5, compasses half a year later prone to slip marks 6, Z-axis lead screw will be walking a long time, noise, often when walking up and down the card 7, Z-axis and Y-axis dust does not good soil too much 8, X-axis and Y-axis lead screw nut is easy to fall, the machine is easy to loose top wire 9, the drive is easy to short circuit, the stepper motor is not easy to turn off the shaft, up and down a clearance to use engraving machine should pay attention to safety with Power 10, engraving machine can not send signals Be caused by: 1) software parameters set incorrectly 2) Machine and computer is not online 3) computer serial port in question 4) software transfer rate is inconsistent with the engraving machine baud rate Solution: 1) re-set parameter 2) Press the "offline" button to make lights off 3) use another serial port 4) to re-set the baud rate laser engraving machine/laser cutting machine/CNC router/wood working CNC router
__________________ http://www.morntech.com/: Laser engraving machine , CNC router |
| Need Help!- Exclude Side From Mop | catabolic | CamBam | 3 | 05-20-2011 04:35 AM |
| Common knowledge for the Maintanence of Laser engraving machine | techfortun | Laser Engraving & Cutting Machines | 0 | 09-11-2009 01:08 AM |
| ANYONE EVER PURCHASE CHINESE CNC ROUTER? (CNC ADVERTISING MACHINE) | protrackcorp | Commercial CNC Wood Routers | 1 | 06-29-2009 02:11 PM |
| sell CNC Woodworking Machine,CNC Advertising Machine | zhangrui1588 | Product Announcements & Manufacturer News | 0 | 05-30-2008 08:43 AM |
| Advertising CNC Machine Time | David M | Employment Opportunity | 28 | 05-18-2007 09:25 AM |
