Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-19-2011, 11:02 AM
fullingdale is on a distinguished road
NewlyDraw
I have a LS3020 Desktop Laser, which came with a copy of NewlyDraw ... no issues when I am etching or cutting stuff from images which are prepared or simple shapes, but I am in need of drawing something myself, similar to the following image.
For my image, I only need maybe four 'fish scales' across, but for the life of me, I cannot get the image to line up perfectly.
(a) any tips on how to get things to line up correctly?
(b) should I be using different software?
Old 10-19-2011, 03:17 PM
DavenUK is on a distinguished road
The LS3020 uses Newlydraw driver board so you will still need to use that to send the jobs to the cutter.
You can use the co-ords in ND to position the drawings or best use something like Draftsight (free) to draw the vectors and then import into ND to cut.
There is also a forum dedicated to LaserScript Machines which you masy find useful ;-)
Dave
Old 10-20-2011, 03:03 AM
Thank you for that
Help with NEWLYDRAW J514 Laser Engraving & Cutting Machines 4 04-17-2011 07:37 PM
Help with NEWLYDRAW J514 Laser Engraving & Cutting Machines 8 04-17-2011 09:07 AM
Help with NEWLYDRAW J514 Engraving Machines 0 04-16-2011 02:23 AM
Newlydraw problem froggygeorge Laser Engraving & Cutting Machines 16 02-04-2011 12:51 PM
Need Help!- NewlyDRAW - Cut In / Cut Out LuAn Laser Engraving & Cutting Machines 2 04-06-2009 12:36 PM
