Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-19-2011, 10:25 AM
malagant is on a distinguished road
2 inch arc from laser tube to the chassis
I just received cheap Chinese 40W CO2 laser (Shenhui Laser). It did came in perfect condition, but it's not working. Problem is this:
Laser error - YouTube
Few pictures of the laser tube:
http://lauri.jamsa.me/pic/laser/2011...2012.53.58.jpg
http://lauri.jamsa.me/pic/laser/2011...2012.53.50.jpg
http://lauri.jamsa.me/pic/laser/2011...2012.54.07.jpg
There is no loose wires on anything like that. The isolation of the high voltage wire seems to be also ok (according the pictures). Still the arc flows to the chassis. Why? And how I can fix this? Of course I have contacted the seller, but I don't want to send the machine back to China - I need to cut stuff!
Old 10-19-2011, 10:53 AM
keebler303 is on a distinguished road
Ha ha, looks exciting! I am not sure it would change things but it doesn't look like you have the water cooling in place??? It could be a bad tube. If the gas micture is wrong or missing (vacuum) then you will not get emission. I'd try it with water cooling but it seems there is a problem with the tube, I have no experience with these tubes so I could be completely wrong, just my $0.02.
Matt
Old 10-19-2011, 10:57 AM
Matt
Water cooling is in place
Old 10-19-2011, 11:19 AM
The water is only in the outside of the tube, not the inside, correct? The ground wire at the other end of the tube is connected to where it should be?
Matt
Old 10-19-2011, 12:16 PM
Matt
I'm not sure about this. I just connected the water inlet pipe to the pump and noticed that the water is circulating properly and no leaks present. Blue wire from the other end of the tube goes to the huge resistor (10 x 2 cm), so yes, I think.
Laser tube gone bad?
Old 10-19-2011, 01:42 PM
Like I said I've no experience with glass laser tubes, though I have experience with lasers and high voltage. I would think that the tube may be bad because the current should travel through the tube, which would present less resistance than jumping a 2 inch gap to the chassis.
Have you talked to the manufacturer? I would think others may have had similar experiences.
Matt
Old 10-19-2011, 02:53 PM
Curley is on a distinguished road
My bad idea.
Old 10-19-2011, 03:31 PM
notexpert is on a distinguished road
Malagant,
Remove the foam rubber from your machine - I think it causes your problem...
-Hannu
Old 10-19-2011, 03:34 PM
Originally Posted by notexpert View Post
Malagant,
-Hannu
I removed it before powering up the device. Device is new, so it might be that the problem is gas leak on the laser tube or something like that. Let's see what the seller says about that. I'll keep you posted.
Old 10-19-2011, 03:49 PM
Double check the isolation of your wiring and add some more (for test). You could also try to clean the surface of the tube to remove any possible conductive stuff from it...
Hope you get your problem solved
-Hannu
  #11   Ban this user!
Old 10-19-2011, 03:59 PM
Exsecratio is on a distinguished road
Tubes dead, and shortly to follow will be your power supply if you allow it to arc like that.
That arc is 22,000 volts, if the loop is across your heart on way to ground it will kill you.
Most laser tubes when they eventually die act this way.
best wishes
Dave
  #12   Ban this user!
Old 10-20-2011, 12:59 AM
Tweakie's Avatar
Tweakie is on a distinguished road
As has already been said - Unfortunately, that is often what happens when the tube is dead. You need a replacement tube.
Tweakie.
CNC is only limited by our imagination.
Laser 150 W RECI laser tube, monster!!!! lamicron Laser Engraving & Cutting Machines 17 11-09-2011 09:11 PM
New Machine Build- We supply you CO2 laser machine also laser tube masterandroger Laser Engraving & Cutting Machines 0 12-23-2010 09:41 PM
70w laser tube lamicron Laser Engraving & Cutting Machines 5 12-10-2008 08:19 AM
bad laser tube CNCadmin Laser Engraving & Cutting Machines 40 07-03-2007 10:23 PM
What laser to cut 1/8 inch plywood? S55 Laser Engraving & Cutting Machines 3 06-12-2007 11:52 AM
