Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-18-2011, 08:33 AM
cheethr is on a distinguished road
Help Needed!!!! Shenhui Laser K40
Ok, please go gentle with me as im a newbie
I recently bought a Shenhi Laser K40 off Ebay, and before someone says yes I know I should not have bought it. However this is too late so need some help going forward to get it working else its just going back on ebay to be sold again.
Download moshidraw, which i have read is cr@p, also read somewhere you can use Corel Draw along side this?
Anyway moshidraw downloaded, machine all plugged in ready to go, the problem I have is when I connect the machine to my computer via the USB it does not recognise it and just keeps looking for software to download. From the instructions recieved with the machine it states just to download moshidraw and you should be ready to go, but it just comes up with usb not connected in moshidraw software. Am i missing something here as I have not been provided with any more software to download.
Really need some help and the seller on ebay is about as good as a chocolate fire guard.
Many Thanks
Old 10-19-2011, 03:10 AM
cinematic2 is on a distinguished road
Check USB cable.
It happens cable needs to be replaced.
When machine is conncted to computer and everything is OK you will see diode shining on machine mainboard near USB port.
If there`s no diode - there`s no connection between software and mainboard
Regards
CNC lasers, constructions, service
Old 10-19-2011, 03:47 AM
Rodney Gold is on a distinguished road
Contact Shenhui directly , they have a few ppl on skype that can help
Blanca Yan (blanca610616) and yarde feng (yardefeng on skype)
Old 10-19-2011, 09:30 AM
mowcius is on a distinguished road
When I bought a very similar machine (which I got last week) it came with a disk with Moshidraw on it - that seemed to install the laser cutter drivers for me.
Which version of Moshidraw are you using and on what operating system?
As Rodney says though, skype might be a reasonable plan if you're awake when they are.
Old 10-26-2011, 11:35 AM
Gadroc is on a distinguished road
I just got my KC-40III had the same problem, but it's fairly easy to fix. The driver is in the moshidraw directory, just tell windows to search there instead of the internet. Easiest way to do this is open up Device Manager (right click on my computer then select properties, and then select device manager) and find the usb device with the yellow exclamation point. Right click on it and say update driver. You should then have options to specify a directory to search through and just point that to the moshidraw directory.
Just an FYI MoshiDraw would crash outputting every time under Windows 7 for me. I had to revert the engraving machine to Windows XP. I also have CorelDraw setup. Just install CorelDraw to the same machine and then in select File -> Options in Moshidraw. There should be a button to "Link CorelDraw". It will add a toolbar in corel draw which lets you export ptl or bmp to moshidraw for cutting/engraving.
Old 10-26-2011, 11:57 AM
Ok i've had a problem with moshidraw now which is that it won't draw shapes/text/anything and it also won't open or import images. I'm going to try different compatibility options on Win 7 or go with Win XP if I have to...
Oh well my experience so far has still been better than I thought it would be. I can cope with some issues on a machine that cost me less than half a grand...
Old 10-26-2011, 12:33 PM
bpoulin is on a distinguished road
All these software programs use legacy versions of file types, if you're saving as a .AI file save it as compatible with version 7 or 8 not one of the CS types. I'm not very familiar with Corel, I use Adobe Illustrator for all my design work. I can't upload a .ai file or I would upload one for you to try to import. PM me with your email and I can email it directly to you.
Old 10-26-2011, 01:03 PM
Oh it's not the file types - I don't get that far - I just click open and it throws up some error that's in random characters or closes itself
Old 10-26-2011, 01:06 PM
Ahhh ok. I'd contact Shenhi Laser and tell them what's wrong and request another copy of the software, it may be a corrupt copy.
Old 10-26-2011, 01:38 PM
It's not corrupt software, as I've downloaded a newer version than what was shipped and it did the same thing. Also the problem manifest itself even when you draw straight in Moshidraw with out other applications. Fundamentally Moshidraw seems to be broken under Windows 7.
At this point I'm ok with Windows XP as I have a old computer doing nothing but running the laser. I use CorelDraw on my laptop to do the drawings and just transfer to the engraving machine to output.
I'm also pretty happy so far especially give the price of these machines. I get my first batch of materials today and will hopefully be giving it a good workout over the weekend to see if it holds up to some real use, vs the easy tests I've done so far.
  #11   Ban this user!
Old 10-26-2011, 02:27 PM
Well that saves me some hassle then.
What did you try on Win 7? Installing it in compatibilty mode? Running in compatibility mode?
  #12   Ban this user!
Old 10-26-2011, 02:37 PM
All of the above. I tried base Win 7 (32bit)... SP1. Run as administrator, run as admin with xp compatibility mode. Install as admin, install as admin in compatibility mode. No matter what I did it would error out trying to output and give me a Data Conversion Error.
The only thing it would do is cut out the outline of the document by clicking fixed position. Worked first time like a charm in windows xp sp3.
SHENHUI LASER romuros Laser Engraving & Cutting Machines 39 03-16-2012 02:45 AM
Thinking of buying a shenhui laser desktoprouters Laser Engraving & Cutting Machines 55 09-21-2011 08:36 PM
Any information about Shenhui Laser DC-G350D? supertronic Laser Engraving & Cutting Machines 7 08-18-2011 04:08 AM
shenhui laser and CNC router machine want to develope agency in Africa and Oceania Shenhuilasercnc Want To Buy...Need help! 0 03-30-2010 10:47 AM
laser kit needed arachid78 Laser Engraving & Cutting Machines 4 02-28-2009 08:04 AM
