Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-16-2011, 07:04 PM
KSky is on a distinguished road
Melco Laser Retrofit
I ended up with a pallet of used Melco Laser engravers, with some brand new laser tubes and other assorted parts. They are pretty old, but in good shape. From what I was told, the cards only work in Windows 98 machines.
The servos are Clifton Precision JDTH-2250-G2-1C. They appear to be a standard 4 wire encoder, 4 wire motor servo.
I've built two CNC routers, so I have some experience here, but not with servos. My question is pretty simple, would it be better to try and retrofit this with stepper motors, or are there inexpensive servo controllers out there that would work?
Old 10-16-2011, 07:58 PM
bpoulin is on a distinguished road
Are you sure they are servos and not steppers?
Old 10-16-2011, 08:29 PM
I assumed they were servos as they have the encoders on the back. I guess I could unplug a motor and touch all the leads together and if it still turns, it's a servo?
Old 10-16-2011, 10:42 PM
Paulette is on a distinguished road
to KSky
I think you need a driver,to run your machine configuration,
We also have agents in USA,You can consult our agent
http://www.morntech.com/: Laser engraving machine , CNC router
Old 10-16-2011, 10:54 PM
I guess I wasn't being clear. I want to scrap the current motor controllers and convert it to using mach3. Not sure if I should either convert to stepper motors or add servo controllers and use the current motors.
Old 10-17-2011, 01:26 AM
Rodney Gold is on a distinguished road
I would either try to get em to work as delivered or part them out for spares , Retrofitting a different motion system is not that viable. You would really need a new motherboard , a new lcd panel , stepper drivers , stepper motors , possibly a new power supply , pulleys , belts ,proximity switches etc. Would be cheaper to buy a Cheap chinese machine without tube and PS and retrofit the RF tubes.
Old 10-17-2011, 08:57 PM
very clear explain,
Need Help!- Retrofit of 40w laser engraver/cutter routout.com drivers dominicburke200 Stepper Motors and Drives 2 05-08-2009 02:15 PM
Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540 GreenLead Benchtop Machines 31 11-26-2008 11:55 PM
Need Help!- camsoft retrofit to a anilam crusader retrofit bowlingmac CamSoft Products 44 07-24-2008 09:00 PM
Laser cutting retrofit? jpm Laser Engraving & Cutting Machines 0 01-17-2008 02:40 PM
Medical CO2 laser tubes for retrofit? wyobmf Laser Engraving & Cutting Machines 2 01-10-2008 07:41 PM
