Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-16-2011, 07:58 AM
harrydejonge is on a distinguished road
lasercut 5.3 language.ini
I have a problem that my lasercut 5.3 software is half chineese and half englisch.
My supplier send me already the same file.
Maybe someone can send me this file. Or give a good sugestion how to get this.
Many thanks
Old 10-16-2011, 11:06 PM
bpoulin is on a distinguished road
email me poulinphotography@gmail.com I will see if I can get you the language file.
Old 11-17-2011, 05:11 AM
restol is on a distinguished road
Hoi Harry,
I have the same problem, I need a better language.ini file for LaserCut 5.3.
My other issue is the config file for the laser itself, which seems to be wrong for my machine, but it is difficult to debug if you don't even have a correct language file, as the important things about my motion controller options are all not in english.
Did you get a correct language.ini file?
met vriendelijke groet, René
Old 11-17-2011, 09:21 AM
cinematic2 is on a distinguished road
Check
CNC lasers, constructions, service
Old 11-17-2011, 09:39 AM
thank you, but unfortunately there is the same issue near the codes for the lasermode, search for string 459_0, 459_1, etc until 459_4, they read for example 459_0=Ä£ÄâÐź which seems chinese to me.
Old 11-17-2011, 09:54 AM
This one is from MPC6535.
Old 11-17-2011, 10:05 AM
You may try to copy/paste strings.
language6535.ini - bratanek65 - Chomikuj.pl
thank you - that helps!! I find some important strings that I am missing, will try to put something together!
best regards
René
Old 11-17-2011, 02:23 PM
I know.
(quotation)
Tags
language, lasercut 5.3
A few ?'s about Lasercut 5.3 Dubliner Laser Engraving & Cutting Machines 10 03-24-2011 11:16 AM
Lasercut 5.0 and 5.1 avetek Laser Engraving & Cutting Machines 23 10-18-2010 10:54 AM
Need LaserCut 5.0 ArturoV Laser Engraving & Cutting Machines 6 12-19-2009 01:26 AM
Lasercut V51 - HELP! TheWorkshopGuy Laser Engraving & Cutting Machines 2 10-05-2009 05:25 AM
Need Help!- Lasercut 5.1 language file rayscott Laser Engraving & Cutting Machines 3 08-30-2008 02:38 AM
