Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-13-2011, 01:06 AM
Tomason is on a distinguished road
Unhappy laser engraving machine:How to avoid waste
As all users know ,when you work with a laser engraving machine, it will make a lot of waste, if used improperly. Especially processing irregular products, and the new material you not familiar with.
Now,I want to know how to avoid waste,can anybody tell me?
Old 10-13-2011, 02:18 AM
Rodney Gold is on a distinguished road
Use it properly to avoid wasting stuff?
Are you wanting to know about "nesting" , that is , fitting the most parts you can into the piece of material you have?
Old 10-13-2011, 02:57 AM
Paulette is on a distinguished road
Smile How to avoid waste
Generally laser engraving machine’s standard configuration always with a red pointing device. When processing irregularly products, you should first observe the carving position with Red light positioning, then do formal process. For material not seen before, should follow the power principle from low to high.
Hope it can help you.good luck to you
http://www.morntech.com/: Laser engraving machine , CNC router
Old 10-13-2011, 03:02 AM
I do not know what you mean,
Old 10-13-2011, 06:46 AM
I don't know what you mean either..
Only way you will learn what settings amd how best to operate the laser without wasting or destroying stuff is by practising and writing down what works for different stuff. Get lots of scraps and try different things on them
Old 10-13-2011, 08:37 PM
Thank you very much,
Old 10-13-2011, 08:38 PM
Thanks a lot,sorry for my poor professional knowledge
Tags
sell laser engraving and cutting machine, laser marking machine lindagstar Trade Shows and Events 4 08-27-2011 05:39 AM
Need Help!- CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser vksingh Laser Engraving & Cutting Machines 2 07-01-2011 10:52 PM
Supply Laser cutting machine and Laser engraving machine sherryguo Product Announcements & Manufacturer News 5 11-27-2007 07:47 AM
