Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 10-08-2011, 06:21 AM
phil1878 is on a distinguished road
cutting 6mm wood
Hi all
Need a laser engraver capable of cutting wood upto 6mm thick. I understand from reading around various posts here that you will have different results depending on the type of wood. Low resin wood, less burning?
So 2 questions really.
1/ Which types of wood would be best considering I would want to engrave the top as well as cut the profile?
2/ What spec of machine would i need (rather than the supplier at this stage). 40W, 60W, higher?
Will probably go for a small work area (A4) at first to keep the cost down, then a larger capacity if I can make it pay.
Phil
Old 10-09-2011, 02:13 AM
Melody-gweike's Avatar
Melody-gweike is on a distinguished road
Cutting 6 mm wood
Hi Phil,
1) Good wood for engraving & cutting is neither too hard nor too soft, No deformation, No crack, easily painted. Most of the woods are OK, but you should not choose as Density board,plywood..
2) 6mm is easy work. You can set different power and speed according to different kinds of wood. But should pay attention to the focal length to avoid burning. If you have a lot of cutting work to do , I suggest 80W. You will have good speed with that. If you engrave more, 60W also Ok.
Old 10-09-2011, 10:46 AM
Rodney Gold is on a distinguished road
To cut 6mm wood with a reasonable edge , you need 150w. You might do some 6mm woods with 60/80w/100w but you will have a lot of charring. A good rule of thumb is that if the wood feels dry and light *alder etc* , it will be easier to cut. Higher resin woods and plys are a huge issue when cutting , trying to cut 6mm teak or ebony or the like will be almost impossible with low powers. Plys have lots of glues and binders , also makes for dreadful cutting.
Old 10-09-2011, 01:34 PM
Melody/Rodney Thanks for your feedback.
Hmm. As I suspected I'll have to choose my wood carefully as a 150w machine is not an option.
Rodney, I have read a lot of posts from you and you clearly speak with a lot of knowledge, so I bow to that... but I would be interested to hear from anyone has successfully cut 6mm wood with a 60w with minimal or no charring, and specifically what was it?
Phil
Old 10-09-2011, 02:08 PM
bpoulin is on a distinguished road
I have cut 1/4" wood with my 80w, which is 6.35mm. No problem cutting at all. Slight charring, but increasing the pressure of the air assist will help that. Also if charring and burning happens more with a particular type of wood, you can look into inert gasses instead of compressed air. The gasses can help reduce charring.
Old 10-09-2011, 07:05 PM
MonoNeuron's Avatar
MonoNeuron is on a distinguished road
Charring is a fact of life when you are cutting wood with a laser but it can be minimised by speed and power. The more power the better and faster you will cut. Also the amount of smoke it will generate is immense so you will also need to set up a fume extractor and vent the smoke outside somewhere.
I can cut 16mm Pine wood at 6mm/sec with my 100 watt laser. I could probably cut faster but I want to make sure it cuts all the way through the knots and also have the part fall free after cutting. Sometimes I set the focus at the top and other times I set it in the middle. It seems to cut better when it's focused at the top probably due to the small focal point getting the burn started.
The charring is minimal and it leaves a dark brown finish, not carbon black, that doesn't rub off on your hands unlike cutting chipboard or thin cardboard.
I haven't tried really thick MDF but I can cut 6mm MDF at 20mm/sec with no problems. Just don't breath in the fumes as it will kill you. :-)
Rich.
I am not completely useless.......I can always serve as a BAD example.
Old 10-09-2011, 10:01 PM
fly007001 is on a distinguished road
hi Phil
100w RECI tube is no problem to cut 6mm wood no matter what kind of wood.
Old 10-10-2011, 12:40 AM
Originally Posted by ozgencmakina View Post
There is no cause of worry. Because there are many help lines to help. Such as- Ozgencmakina Specializing in PVC processing machines,Pvc window machines,Windows manufacturing machines,Pvc cutting machine,joinery machines,Aluminium windows and doors machines, following the latest developments in the sector as well as his production, post-sales technical support and spare part services are provided to its customers every time has been based on customer satisfaction.
http://www.pvcmachine.com/aluminium-...machinery.html
Is this just spam? Because it has no relevance to the conversation..
Old 10-10-2011, 01:50 AM
MaryB is on a distinguished road
I cut 6mm with my 60 watt all the time with no problems. 100% power and I think I was at 7mm/s
Old 10-10-2011, 09:02 AM
Just a friendly tip. To extend the life of your laser tube, avoid using it 100% You wold be better off firing it at 90%, slowing down the speed, and increasing the air pressure of the air assist. Think of it this way, would you drive your car with engine revving at it's maximum RPM all the time? Yes it can handle it, but for how long?
  #11   Ban this user!
Old 10-10-2011, 09:18 AM
cinematic2 is on a distinguished road
60W RF Synrad is enough for 6mm wood.
CNC lasers, constructions, service
  #12   Ban this user!
Old 10-11-2011, 09:36 PM
Cat cat is on a distinguished road
Originally Posted by phil1878 View Post
Hi all
Phil
Hello, Phil!
Do you remember me? We have contacted by emails.
About the wood, may different according to the density of the wood. If the soft one, 60w can be Ok. If the hard one, 60w may difficult. So we often take acrylic as standard.
Salley
Web: Liaocheng Xinxing Electronic Co., Ltd.
E-mail: sales07@raylaser.cn Or raylaser06@hotmail.com
Laser Wood Cutting Autonow Laser Engraving & Cutting Machines 11 12-08-2011 07:09 AM
Newbie- Cutting Aluminum vs Wood TMc DIY-CNC Router Table Machines 5 03-28-2009 09:26 AM
CUTTING WOOD GEARS ClockMaster WoodWorking 0 11-14-2007 10:49 AM
Cutting load in wood? boblon DIY-CNC Router Table Machines 5 02-26-2007 05:02 AM
Cutting wood with OneCNC. nagjames OneCNC 3 12-20-2005 04:54 PM
