Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-28-2011, 06:18 AM
fliegeregge is on a distinguished road
MPC03 Problem / Patchboard P68
Hi all,
i am working with a CX-1260 Laser machine 80W and LAsercut 5.0 with
MPC03 Card.
It worked very well since 3 years. Some Tube changing, some software crashes... the small things , ya know...
But today - PROBLEMS - !!
The motors didnt work anymore !
Checklist:
Driver/Software/Dog - OK
MPC03 Card: The green LED No. 4 is on, if I move the head with the software the LEDs go on as they should. Card semms ok and no errors in software (driver).
But the head didnt move !
Then i checked the P68 Patchboard inside the machine. ALL LEDs are off !
I try to move the head over the control board - nothing happens.
No movement, no LEDs.
5V ok.
Now checking the power supply if there is mistake.
ANY IDEA ???? Please Help.
Old 09-28-2011, 03:39 PM
Hi again,
maybe someone is familiar with that kind of trouble.
First the things that are checked and ok.
-Cant move the head by hand. The motors are "on break" and OK. I have to switch off the machine then they are free. OK.
-LED D1,D2,D3,D4 on PCI Card MPC03 are on/off as they should be when moving X/Y axis in the software.
-Laser can be fired with the Test-Button.
-No error message from software - Software/Card Driver ok.
-Green Lights and voltage on the drivers (the black boxes).
-Chip 26LS31 changed twice on the MPC03 Board. All ok.
Now the bad stuff.
-The Motors (X-, and Y-axis) dont move.
-All lights on the P68-LV Breakout-Board are OFF.
-I can NOT move the head. Wether by pushing the buttons on machine nor by software.
More information for troubleshooting.
If i push a move-button on the machine the corresponding wires on the left side of the P68-LV Board says 4.88V.
But nothing happens with the motors.
The Power-LED and ALL axis lamps on the P68 are OFF.
The Multimeter says 4.88V between pin 1 and 2 on the P68-LV board.
The fan of the big main power-supply is working.
There is another big "High-Voltage" Device above the P68. It show a green LED and its fan is also working.
There is a smaller "High-Voltage" Device with lots of holes in the cover. The green LED inside is OFF.
Any Idea ????? Urgent ! Winter is coming !!
Many thanks !
Old 01-11-2012, 03:41 AM
INFOMAC is on a distinguished road
I think you need to replace P68-LV
bye
Tags
error, malfunction, mpc03, stepping motor
SUDA SL9060 with MPC03 buddhafragt Laser Engraving & Cutting Machines 4 08-25-2011 03:53 AM
MPC03 card adrianhdezch Laser Engraving & Cutting Machines 2 05-12-2011 07:19 PM
Replacement for MPC03 Controller vincentp Laser Engraving & Cutting Machines 16 11-19-2009 06:48 PM
HELP ME ABOUT MPC03-LT CARD. Haroonalvi Laser Engraving & Cutting Machines 4 12-10-2008 08:26 AM
MPC03/dedicated software 5.0 moos Laser Engraving & Cutting Machines 7 11-21-2007 06:16 AM
