Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-25-2011, 06:21 PM
sabastion is on a distinguished road
Home made CNC Laser
Need a CNC laser to cut up to 1 inch thick x 20" x 24" 0r longer plastics (plexiglass, polycarbonate) and for etching and engraving.
Can one be built cheaper than can be bought? I have looked in these forums but couldnt find anything easily on this topic. I do pull up a lot of stuff from instructables web sight though.
Starting new Home based computer mod and sign business with little money to spend up front. your suggestion are appreciated...ty
Old 09-25-2011, 11:22 PM
Rodney Gold is on a distinguished road
You will struggle to cut 1" thickness of anything due to various factors , you might do acrylic as its a wave guide to the laser beam itself , but polycarb won't cut well.
If you are looking to buy a mainstream laser , you could save by building it yourself , however if you compare a DIY with a chinese laser, I don't believe you will save any significant amount over purchasing.
Old 09-26-2011, 03:46 PM
Ok...then I will use table saw to cut the material to the size I want.
What is a minimum CNC laser you would suggest for engraving and etching=(frost look)?
Old 09-27-2011, 02:06 AM
I would buy a 900 x 600 mm 80w Reci tubed laser , it will cost you around $4000 with upgrades and spares , you could go smaller and cheaper if funds are an issue , tho $4k + shipping is pretty cheap for a machine as capable as that.
Add US made laser module to Chinese laser? glintid Laser Engraving & Cutting Machines 13 05-02-2012 02:43 AM
New Machine Build- Home made folded cavity CO2 laser tube rogerjames Laser Engraving & Cutting Machines 17 08-14-2010 11:21 AM
Just IN- laser home made magdy_micheal Product Announcements & Manufacturer News 0 07-04-2010 12:13 PM
Home made laser MonoNeuron Videos 17 09-18-2008 04:34 PM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 05:54 PM
