Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-24-2011, 12:08 PM
curious is on a distinguished road
s&a cw-5200 chiller
after 5 min cutting 85% power
temp. of water is already 35 C
room temp 20 C
is this normal
or is the chiller defect ?
Old 09-24-2011, 01:22 PM
Blackjax is on a distinguished road
not normal on mine i can run mine all day and not hit 35 i use automotive antifreeze in my chiller 50/50 mix using distilled water
Old 09-24-2011, 01:40 PM
what are you doing that you need that kinda power all the time?
Old 09-24-2011, 02:18 PM
cutting laminated wood/plywood 6mm
but i wonder if the chiller is not broke.
Old 09-24-2011, 02:59 PM
Might wanna run a industrial chiller or toss a wort chiller inline or make your own wort chiller by twisting copper tubing into length of coil its a simple heat exchange
Old 09-25-2011, 01:59 AM
cinematic2 is on a distinguished road
Just check you chiller settings first.
CNC lasers, constructions, service
Old 09-25-2011, 01:02 PM
checked it twice today.
the black pump for the cooling gas/liquid is very hot
all tubes of copper and th ebig cooling block cold !!!!
water is warm
i get the feeling that there is no R404 or freon or whatever must be in there
if i take a look at a standard fridge ,the cooling block is always hot !
something is wrong here
Old 09-25-2011, 04:56 PM
So call nearest fridge service.
Old 09-29-2011, 01:12 PM
and so i did.
it turned out ,the compressor didnt turn/work
they measured 7,2 Amps ,thats more than the whole machine should use.
conclusion compressor broke.
i asked a new part .and they promised to send it to me.
now we wait how fast it will be delivered.
Old 11-15-2011, 05:34 PM
pjcampbell is on a distinguished road
Would a chiller like this work to cool glycol from 200F (93C) down to 75F (23.8C)? do you know what the GPM or Litres per minute capacity it has? Goal - cool 31 gallons of beer down as quickly as possible. Glycol would be used with a heat exchanger.
  #11   Ban this user!
Old 11-16-2011, 07:39 AM
CW5000 (similiar to 5200) has about 2400-3000 Btu/h
So you may count what you need.
  #12   Ban this user!
Old 12-04-2011, 02:26 PM
its all working now
s&a send new pump and i bought also a new extra chiller
good to know, there are some good reliable chinese producers
what kind of chiller for an roboform 31 blackdogmachine EDM Machines 0 08-26-2011 09:25 AM
Free Water Chiller Til 8/11/11 fslaserboy Engraving Machines 0 08-09-2011 06:30 PM
Need Help!- Okuma MX45VAE Oil Chiller wjjosep Okuma 1 07-26-2011 04:25 PM
Problem- Chinese Chiller Dubliner Laser Engraving & Cutting Machines 8 10-06-2010 02:28 PM
Spindle Chiller Coolant furnman487 Fadal 3 03-23-2006 05:16 PM
