Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-20-2011, 09:54 PM
Nubbly5 is on a distinguished road
Laser Tube Troubles
We recently purchased an 80w CO2 laser from Strong Signstec and shipped it to Aus. We had read the many and various disaster stories of importing a laser from China but due to the cost comparison ($7,000 for an 80w v $35,000 for a 50w) we armed ourselves with as much info as we could, held our noses and dived in.
The importing process was smoooooooth thanks to our Customs Broker (no duties to be paid just GST and port handling fees) and we picked up our laser engraver with no problems. The packaging seemed fine and the build quality looked acceptable.
We have had some software problems. The CD loaded with LaserCut 5.3 was corrupt but Wang helped solve that OK.
However..... and now it's a big however...... when we first set up the laser, attached the cooler and ensured bubbles were removed from the system, all appeared OK. The laser fired fine, cooler seemed to work perfectly. Then all of a sudden, no laser firing.
After some fiddling around we worked out that the laser tube had blown a small hole into the inner part of the tube, flooding the enitre tube with water.
We had ordered a spare tube (because of the all the problems as posted) to ensure that if something like this happened we had a spare to work with. So we connected the new tube but now we still have a non-firing laser.
So the long way round to my question is this..... can a flooded laser cause enough of a power surge to short out the power supply OR would a faulty power supply be able to cause a spike enough to damage the laser?
Any help or suggestions would be gratefully received.
Old 09-20-2011, 11:51 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
there is probably another problem, just shorting the two electrodes that feed that laser most likely wouldn't blow the PS (if it is built correctly) it's not like your shorting a winding and generally if you have it turned to 40w or 10w that's all the ps is going to feed it.
could be the tube is just bad. or like you surmised, the PS had an issue and blew the tube.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 09-21-2011, 01:53 AM
Cat cat is on a distinguished road
I'm sorry to hear that.
1. May the tube is broken during the transport
2. May you set the wrong connections
And the tube and power supply should be match with each other
Hope it will be helpful
Salley
sales07@raylaser.cn raylaser06@hotmails.com
Liaocheng Xinxing Electronic Co., Ltd.
Old 09-21-2011, 01:56 AM
Originally Posted by hina2526 View Post
I'm doing a science project and need to use a laser pointer. The project is about making a toy for children aged 9 to 12.
Can you tell me some details of your work? Do you want a laser engraving machine or cutting machine? What material do you use? May I can recommend for you.
Salley
sales07@raylaser.cn raylaser06@hotmail.com
Old 09-21-2011, 04:59 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Have you checked the fuse associated with the PSU ??
Tweakie.
CNC is only limited by our imagination.
Old 09-22-2011, 03:23 AM
We checked the PSU and there appears to be a fuse within the body of the unit which seems OK. There is still power going to the PSU (seemingly) as the fan of the unit runs.
Anything else we should check?
Really has been the nightmare we hoped it wouldn't be as we had also purchased a programmable paper cutter from the same company and presto - that also doesn't work. Apparently the mother board. New one sent but the DHL tracking number relates to a package that has already been delivered into Aust. Sigh.......
If we don't get some resolution I guess all we can do is contest the charge through our credit card company for goods that don't function.
Old 09-22-2011, 04:13 AM
Tweakie's Avatar
It's difficult suggesting any checks you can do on the PSU because of the high voltages involved and the associated danger to health but a picture of the PSU may help me identify the area for you to look for problems.
(I am not a great expert because I have only repaired two of the Chinese PSU's so far).
Tweakie.
Old 09-22-2011, 04:54 AM
wshappy's Avatar
wshappy is on a distinguished road
what is the meaning of PUS, hope could learn about it. my email is mornp@morntech.com
Old 09-22-2011, 04:59 AM
Hi Tweekie thanks for the advice so far.
I'm not sure if these pics are quite what you are after but if not just let me know what I should be photographing other than the outside of the PSU
I'm assuming PSU is Power Supply Unit...........
Old 09-22-2011, 05:34 AM
Tweakie's Avatar
That's handy, a diagram was posted in another thread. This will not be exactly the circuit of your PSU but it will be similar. The two power transistors (I have circled in red) would be my first area to check - they will be mounted on a heatsink. Any visual damage, open or short circuit with a meter and they need to be replaced as a pair. (Use the transistor part numbers marked on existing parts not circuit diagram).
You also need to thoroughly, visually, check the rest of the board for signs of damage / component failure - often high voltage stuff leaves plenty of visual signs of failure.
Hope this helps,
Tweakie.
  #11   Ban this user!
Old 09-22-2011, 12:11 PM
Rodney Gold is on a distinguished road
That looks like a RECI dy10 Power supply . they about $150 or so , get one from RECI direct.
check to see that there isnt a safety interlock that is preventing firing , like an open door or water flow sensor.
  #12   Ban this user!
Old 09-23-2011, 09:54 PM
Hi Rodney
I have sent 4 email to RECI havent had a reply yet. Is there any easy way to get in contact with them.
New Machine Build- We supply you CO2 laser machine also laser tube masterandroger Laser Engraving & Cutting Machines 0 12-23-2010 09:41 PM
Chineese laser troubles JimMacNab Laser Engraving & Cutting Machines 10 03-20-2009 08:18 AM
Laser Tube Help FlyGuy007 Laser Engraving & Cutting Machines 14 09-06-2008 02:50 PM
Is my laser tube ok? PaioX Laser Engraving & Cutting Machines 4 07-23-2007 03:34 AM
bad laser tube CNCadmin Laser Engraving & Cutting Machines 40 07-03-2007 10:23 PM
