Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-20-2011, 03:06 AM
Argonista is on a distinguished road
CNC Laser Cutting Machine - I just want one
I run a metal fabrication shop in Perth Australia. I want to purchase a CNC Laser Cutting Machine that will take 2400x1200mm sheets and cut up to 12mm steel and 4mm aluminium. Budget is about $100,000. 2nd hand would be considered. What do I need to know? Good links for research would be appreciated. Would consider overseas purchase.
Old 09-20-2011, 10:51 PM
Benonymous's Avatar
Benonymous is on a distinguished road
This would cover your requirements and then some!
Home | SMC Manufacturing - Precision Sheetmetal
I have no idea how much they want for it but it looks expensive :-)
Old 09-20-2011, 11:23 PM
bpoulin is on a distinguished road
See that tag that says Cincinnati on the side? I'm guessing 100K would be a good deposit until you paid in full lol.
Old 09-24-2011, 02:16 AM
Benonymous's Avatar
I suspected as much but it will cut 12mm steel
Argonista, I was researching laser cutters and settled on "Golden Laser" as my preferred manufacturer. I wanted a solid state laser and theirs went up to 600W. I think this unit, the largest practical one for me, would cut up to 8mm steel and 3mm aluminium. The representative I was dealing with suggested I should get a plasma cutter if I wanted to go over 8mm steel and actually, I think that's a better idea. Lasers have all sorts of requirements for cooling and maintenance which plasma cutters dont. The only thing about a plasma is that it has a bigger kerf and less smooth edge finish. Apart from that, a decent plasma cutter is much cheaper and less hassle.
Old 09-24-2011, 07:24 PM
Can you fit a plasma torch to a laser cutter or would I need a separate CNC router for it?
Old 09-26-2011, 01:38 AM
I've heard of some combo units, but keep in mind most commercial units you're dealing with some sort of compromise. A laser adapted to plasma wouldn't be as good as a dedicated plasma. Also have you looked into waterjet cutters? I don't know what thickness they can cut, but I've heard they have a cleaner cut.
Old 09-27-2011, 04:18 AM
ellalaser's Avatar
ellalaser is on a distinguished road
our 650W Yag laser cutter can cut up to 10mm steel, 12mm would need higher power, cut 4mm aluminium is ok, we have cutting bed 1300mm*2500mm. with laser cutter the precision is high and obviously better effect than waterjet machine. I dont know if our machine can meet your target since i'm not in sales dept. let me know your contact mail. company infor, i can have our sales engineer give you cost according to your requirement.
Old 10-10-2011, 01:23 AM
maggielfw is on a distinguished road
suggestion
for cutting metal material, I think you can take this Future Anyway Laser into consideration. It produce metal laser cutter. Its 2500mm*1300mm metal cutting machine is within the range you want to cut. This email address falaser1@yahoo.com you can contact.
Old 10-10-2011, 03:42 AM
fly007001 is on a distinguished road
plama cutter is special cut steel,and the price is lower than $100,000
plasma cutter is better to cut steel, and price is lower than 10.000usd. if you like feel free to make contact with me
sell laser engraving and cutting machine, laser marking machine lindagstar Trade Shows and Events 4 08-27-2011 05:39 AM
Cost effective metal laser cutting solution: YAG metal laser cutting machine hanzlaser Trade Shows and Events 1 08-04-2011 04:00 AM
Need Help!- CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser vksingh Laser Engraving & Cutting Machines 2 07-01-2011 10:52 PM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
Supply Laser cutting machine and Laser engraving machine sherryguo Product Announcements & Manufacturer News 5 11-27-2007 07:47 AM
