Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-19-2011, 02:20 AM
inowator is on a distinguished road
DC-K40IV Problem, need help!
Hello everyone,
1st We bought a Chinese laser DC-K40IV. When you start working, ie when he sent in Corel in Moshi, skipped work or fit in the middle of a job and return to point zero? Is it a problem with drivers, does not seem to me that the machine is wrong, if someone can help me?
2nd Is it possible to somehow connect to different DC-K40IV, it has a new panel, plugin? Quite a vague link to the Corel software moshi?
3rd Is it possible some other software to use instead of Moshi?
I'm from Croatia and I hope that you understand my English language!
Thank you
daewoo puma 12lb tape format problem/parameter problem robb12877 Daewoo/Doosan 0 08-25-2011 12:13 AM
Surface finish problem - Could you please help me overcome this problem? DMBGO EMCO Lathe 5 08-04-2010 05:33 PM
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
