10-12-2011, 10:47 PM
Originally Posted by Rodney Gold Turn your machine off and Hold the Auto Focus while turning it on. When it intializes it will allow you to test ram , motors , laser etc.
Its now in diagnostic mode.
These lasers use safety interlocks . if any door is open or one of the magnetic safety locks is open or faulty , the laser will not fire. You need to use magnets to bypass em if you are trying to fire with a door open or if one of em is open.
Even in diagnostic mode , if the safety interlock circuit is open , the laser WILL NOT FIRE!!! If you cant bypass the switches with magnets , then trace the circuit to the motherboard and just join the 2 wires coming in (which will make the circuit)
Of all this doesnt work , Check the laser as well , it should be a synrad , mail synrad for some diagnostics if it isnt working , it needs a specific voltage and there is a led on the laser that should light...ask em. They can determine whether its a machine problem or a laser issue. |
I tried the diagnostic mode and although the display screen "laser" light is flashing red the actual laser is not firing. By "doors" open does this include all access panels or is this just referring to the main lid? Im very frustrated with this machine. The laser is actually not a Snyrad but is actually a Coherent model GEM. They of course would not give me any advice or support due to the age of the laser.
I would like to just sell this machine, any ideas what it is worth both in its current condition (everything functioning except laser, includes laptop with drivers/coreldraw) and also if I were to get the laser working again? Im open to all offers. Thanks again for any suggestions |
