Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-07-2011, 02:32 PM
curious is on a distinguished road
engrave on glass
i tried to engrave photo on glass ,but the quality is not good
if i take the same on wood ,its way better.
someone knows how to improve quality ?
Old 09-08-2011, 08:17 AM
fantasy2 is on a distinguished road
Double check focus height, and try to change the velocity. Covering the glass with wet paper could also be a solution.
Old 09-08-2011, 09:40 AM
zax15uk is on a distinguished road
You need to use a low resolution (dpi) for glass to look good, the image is created by micro fractures so if you don't have sufficient spacing between points it will look blurred.
A damp paper towel on the surface can help too as it reduces the fracture size which allows a higher resolution image.
The type of glass is also a factor, cheap glass seems to work better. Avoid any crystal or thermal glass as it will shatter.
Zax.
Old 09-08-2011, 12:44 PM
thanks ,i will try the damp/wet paper tomorrow
what dpi you suggest ?
Old 09-15-2011, 10:43 PM
Cat cat is on a distinguished road
Smile
When we test the materials, we often set the DPI of the image 600-1200
Hope it will be help.
Salley
raylaser06@hotmail.com
Liaocheng Xinxing Electronic Co., Ltd.
Old 09-16-2011, 06:46 AM
kofi_sunic is on a distinguished road
Diode End Pump Laser Module Works so Well On Glass Surface
Old 09-26-2011, 01:55 AM
bpoulin is on a distinguished road
If you're engraving something other than a photograph, go with sand etching, for less than $100 you can go to harbor freight and get a air eraser, some aluminum oxide media, and a pressure regulator. The sand etching will look much nicer than laser. You can use sign vinyl as your masking.
Old 09-27-2011, 05:56 AM
dingbat is on a distinguished road
How do you cut the sign vinyl? Do you use a knife cutter, or can this stuff be lasered too?
I'm a little wary on account of the fumes hazard for the optics. PVC is a no-no, how about thin vinyl sheet?
Old 09-27-2011, 08:30 AM
I use a knife cutter, I run a sign biz but I just use a cheap $200 chinese vinyl cutter for these jobs. If you do some research there are polyester based vinyls out there instead of PVC based. The polyester ones are laser safe. I couldn't tell you which ones those are, but I'm sure if you ask around someone will know.
Old 09-27-2011, 08:32 AM
You probably won't like the look of lasered vinyl either I forgot to mention it melts the vinyl pretty bad. You'd be better off looking for a cheap vinyl cutter, I've seen some 24" ones on ebay for less than $200.
Using metal CNC mill to engrave glass? zaebis Engraving Machines 4 12-01-2010 03:27 PM
using the indexer to engrave glass woodman08 LOGILASE 9060/12080/150120 / 250120 cnc lasers 0 03-07-2010 06:23 PM
New Machine Build- cut and engrave at which speed? zaheer0047 Laser Engraving & Cutting Machines 2 01-07-2009 11:59 PM
how to engrave cob Mastercam 27 10-17-2008 02:51 PM
Mounting rails on glass - how flat is glass? Swiss Linear and Rotary Motion 50 07-25-2008 02:10 AM
