| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| I've been working on making these things(MAKE | Laser-Cut Polygonal Sculptures), using acrylic from a local supplier. I'd like to make a few more, with the aim of producing wearable pieces instead of heavy stationary pieces. To that end I've been thinking about using cardboard or thick card stock for the large panels. It would be cheaper, lighter, and most importantly, would not shatter if dropped. My problem now is that I don't know where to find sheets of card stock in large sizes (~17x23 in) If there is a plastic that can be laser cut that is also slightly flexible and light that would be even better. This isn't very precise, but the semi-rigid, slightly transparent plastic used to cover binders would be perfect. Any help would be greatly appreciated. |
| I have cut basic designs out of coroplast, such as arrows or cut out designs. It cuts nicely, but you need a knife to finish the separation. The veins in coroplast won't burn off as quick as the front and back piece. I just take a razor and run it in the cut out hole and cut through the veins, it works well and very quickly. |
| Tags |
| laser cutting, material sourcing, material type, materials |
| May we know your experience of Materials, Cutting Depth which Laser tube could do | echojdlaser | Laser Engraving & Cutting Machines | 4 | 01-24-2011 07:51 PM |
| Newbie- Tips on laser cutting soft materials | drmitsos | Laser Engraving & Cutting Machines | 4 | 06-12-2010 12:52 AM |
| Newbie- Cutting XPS foam with cheap laser? | aleksazr | Laser Engraving & Cutting Machines | 1 | 02-14-2010 08:31 AM |
| laser cutting tough, light, flexible sheet materials? | vacpress | Laser Engraving & Cutting Machines | 4 | 01-11-2008 07:36 PM |
| Where do you get materials... cheap? | Sporqster | General Metalwork Discussion | 17 | 06-19-2005 03:36 PM |
