Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 09-02-2011, 11:39 AM
diegope is on a distinguished road
servo vs stepper
hello all
we'll buy a machine soon from a chinese vendor. we'll start a business with it and have the option of choosing between servo and stepper. we've been doing a bit of online research on this with no final conclusion.
it'd be great to hear some first hand accounts on what's best. in terms of reliability, speed, maintenance (bear in mind we probably won't have much support from the anufacturer)
many thanks.
Old 09-02-2011, 11:51 AM
Al_The_Man's Avatar
Servo's are considered the better choice, steppers are mainly used to keep the cost factor down.
AC or BLDC servo's are very reliable now, due to no brushes, (I am assuming the machine has these?) If you have DC servo's then there is a maintenance issue of keeping track of brush wear over a period of time.
I would find out what make model they offer and the future availability of motors and drives.
Old 09-05-2011, 12:07 PM
AJ Solutions is on a distinguished road
Stepper motors are the better choice for raster engraving, servo is better for cutting. The stepper word says it already : it makes tiny steps. When raster engraving you will find these machines faster, they have less accelleration and decelleration. Servo do not make these tiny steps and when cutting acrylic you will have a smoother result as compared to stepper. This result is drastically different!!
I have sold ULS (steppers) and Epilog (servo) in NL (Holland) so I know the differences quite well...
Old 09-05-2011, 12:42 PM
Al_The_Man's Avatar
One only has to read of the application contests won by the likes of Galil Motion etc to refute this.
I presently am using 2000 count encoders with a resolution of x4 and am positioning servo's with an in position error of zero to one pulse resolution of .000062".
And 2000 count encoders are considered rather coarse by today's standards.
One example I alluded to for ultra servo control.
http://www.galilmc.com/support/servotrends/st_10_08.pdf
Old 09-05-2011, 12:50 PM
Ofcoarse you can have very good results when using a stepper. Only you have to set the DPI/PPI settings higher when doing so. This means you have to work slower and this is mostly not the way people want it. I sold these machines 8 years ago so in the meantime the steppers will have improved.
8 years ago the differences between the cutting on 600 dpi/ppi between ULS and Epilog was very noticeable.
I only shared my personal findings as well as the sales criterium of Epilog itself...
Old 09-05-2011, 01:24 PM
hub hub is offline
hub is on a distinguished road
Originally Posted by diegope View Post
hello all
many thanks.
Reliabilty, speed, maintenance.. Servos. (AC)
http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
Stepper Servo Mariss Freimanis Gecko Drives 30 04-25-2010 10:33 PM
Need Help!- Servo vs Stepper? Eusk Gecko Drives 0 03-03-2010 09:46 PM
STEPPER v/s SERVO sanjiv Stepper Motors and Drives 2 11-15-2007 04:29 AM
Servo stepper ? doctor_itchy Stepper Motors and Drives 6 03-18-2007 04:06 PM
