Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-21-2011, 12:17 AM
Shade is on a distinguished road
Tips And Helps for laser engraving art
Im starting this thread to share some tips and shortcuts that i have found while searching the net and engraving
Repost of skipw (Great ref for helping ppl)
Laser pictures info
These are kind of basic but it's a good start. Reposted from an earlier post.
As I know there is no direct information to show how to get a good results in engraving images by using any software, but in general the concept is to convert the image to gray scale mode then black&white , or black&white directly, but the software must have a verity of options to use when converting to black&white, this can be found in Adobe Photoshop & CorelDraw, for example (Halftone, error diffusion, ordered, line art, stucki, ...).
choosing one of these methods will give a deferent engraving effects according to the pattern & number of dots produced.
the steps can be as follows:
-the image resolution should be 300dpi to get a good result
-if the resolution is less than 300dpi then rescan or resample the image
-convert the image to black&white using diffusion Dither, stucki, or Halftone method to get the best details on the engraved image.
-convert the image to black&white by any other methods to get artistic effects on the engraved image.
-every image need some fine tune before or during conversion.
Steps in CorelDraw(12 & 13):
->import the image
-> select the image
- -> select Bitmaps Menu
- -> select Mode
- -> select Black& white 1-Bit
->select conversion method [stucki] and vary the intensity
Steps in Photoshop:
->open the image
-> select image Menu
- -> select Mode
- -> select Grayscale
- -> select Mode
- ->select Bitmap
->select method [Diffusion Dither] and output 300 pixels/inch
Thx to Skipw
Shade
Old 08-21-2011, 12:22 AM
Smile Graphics
I have found a good site for ppl trying to convert color pics for engraving that dont have something like photograv but have photoshop
ePaperPress
Download the action file and load (preset for photoshop) and use the pen and ink one
This should get u very close in a few clicks
Shade
Old 08-21-2011, 12:34 AM
Smile Mirrors
I havent tried this but i heard a few ppl say they did i this way
When engraving th front of a mirror u will destroy ur laser by having the beam bounce back from the mirror
The way ppl have gotten around this was to put wet paper down on the surface (the wet keep the paper from catching fire and the paper reduces the reflection greatly
Shade
Old 08-21-2011, 12:42 AM
Smile Colorfilling
I have tried this and it works well
When engraving glass or other hard surfaces if u then want to go along and colorfill (put paint or other color agents in the engraved grooves) but dont want it to stick to the unengraved surface
Spray the surface with water and 10% dishwashing liquid with a spray bottle on the surface which leaves a very thin clear oil based film and when u engrave it burns away only the point of contact giving a point to attatch to
This should make it easier to clear away excess coloring
Shade
Old 08-21-2011, 01:06 AM
Smile If anyone has more ideas or suggestion pls add
many thx
shade
Old 08-21-2011, 12:42 PM
Rodney Gold is on a distinguished road
There is a huge amount of info at
Engravers Forum
Search for "the gold method" or "gold method" there for a free alternative to photograv
Old 08-21-2011, 01:03 PM
Shade
Thats not really accurate , the laser actually microfractures the glass when it hits it and does not reflect back due to the shatter , you might have reflections if you try engrave highly polished metals. The wet paper on glass is actually a damper so the microfracturing is controlled and it actually acts as a heat sink for the glass around the point where the laser fires so that you have more control over the fracturing - the laser acts by heating impurities and the glass itself and the tremperature gradient makes it fracture..However your wet paper on glass is actually a very good tip as it gives much smoother engraving , the laser does not do glass well, the paper gives a more sandblasted effect.
Old 08-25-2011, 12:58 PM
herby08 is on a distinguished road
40WCO2 laser trouble
hi all
I am new to laser and bought a 40WCO2 china laser.
now I try to find out what it could be that I can not regulate the laser current
with the pot, does not matter how I turn it the current stays pretty much the same 2 - 5 mA only if the laser has to go a longer way across it jumps for a fraction of a second to 15 to 20mA
any help would be apriciated
thanks walt
Old 09-11-2011, 09:58 AM
bpoulin is on a distinguished road
Originally Posted by herby08 View Post
hi all
thanks walt
If you want this question answered, you really need to start your own thread.
Old 02-23-2012, 02:05 AM
windtigertim is on a distinguished road
Hi, this is my first post.
I have built a CNC mill using the eBay TB6560 4 axis driver board.
I recently bought a 12 Volt LASER diode and driver board capable of burning/etching into timber/dark plastic..
I am not worried about PWM etc. I just want the LASER to turn on/off with a Z axis movement.
I can build a TTL triggered relay to interface between a pin and my laser driver board.
What I am wondering is how do I physically wire my LASER Diode & Driver to this particular board?
Are there any outputs plugs on this board that i can directly wire to, or do I need to solder a wire from the printer port connector?
Need Help!- plywood engraving tips Gary123xyz Laser Engraving & Cutting Machines 3 08-15-2010 05:12 AM
corel draw tips - please help - engraving portrait to wood mx_race Laser Engraving & Cutting Machines 13 04-29-2010 08:44 AM
Need Help!- Engraving Tips & Techniques CMWR Engraving Machines 6 04-07-2010 04:25 AM
Engraving tips? DeusExMachina General Material Machining Solutions 4 02-01-2009 08:49 PM
