Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-18-2011, 11:39 PM
JRC413 is on a distinguished road
LaserPro Explorer software?
Hello everyone,
My company just aquired a Laserpro Explorer laser engraver from a company going out of business. The machine powers up but we did not receive any software at all with this machine and cannot find any info on it. We are just trying to figure out what we need to get this thing up and running. On a side note we are now using a MORNtech laser engraver (china version) which simply runs using Coreldraw with a Macro sofware patch so this is all we know. Thanks for any information available, sorry for the lack of knowledge with this stuff.
Old 08-19-2011, 02:54 AM
OldEngraver is on a distinguished road
GCC Lasers run from a printer driver, which means you can send files from many different graphics programs, but Coreldraw is the most popular. The printer driver is usually available from GCC, Jorlink USA, or Litografa's Site.
Old 08-19-2011, 12:14 PM
thanks for the info, I'll check with GCC
Old 08-26-2011, 12:51 PM
Well heres an update, I finally got everything installed and functioning correctly. Only problem now is when I print something in corel draw the machine will go through the motions and act like it is printing the job but no laser comes on and burns the artwork. ot sure if this could be a setting issue or if I have a bad laser. Any test functions for this machine? Thanks again for all the help!
Old 08-26-2011, 03:01 PM
Magnetic switches
If any of the magnetic switches on the doors are not in contact, the laser will not fire. You should make sure all doors are fully closed (lid and pass through). Keep an eye on the laser indicator. If it does not flash red while the machine is running, the laser is not firing.
Old 08-26-2011, 03:05 PM
The red light on the display that says laser is illuminated during the printing process but still nothing is actually being burned. Very confusing.
Old 08-26-2011, 04:48 PM
notexpert is on a distinguished road
Sounds like your laser beam is out of alignment... ? You should check the beam way from the first mirror to the last one.
Just guessing - regards,
Hannu
Old 08-26-2011, 05:00 PM
I'll check that, thanks
Need Help!- GCC Laserpro C180 SPCM Laser Engraving & Cutting Machines 0 08-17-2011 09:21 PM
Need Help!- Where to buy laserpro parts lasernewb Laser Engraving & Cutting Machines 1 05-23-2011 01:04 PM
LaserPro or Epilog laser_1 Laser Engraving & Cutting Machines 10 02-24-2011 08:29 AM
Need Help!- Bridgeport Explorer DX 32 Programming Software minton Bridgeport and Hardinge Mills 1 09-27-2010 08:01 AM
Laserpro Explorer / Pinnacle ZX & Solidworks obrockmeier Laser Engraving & Cutting Machines 1 05-11-2007 04:15 AM
