Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-10-2011, 04:35 AM
Pater G. is on a distinguished road
JQ4030 REVIEW
After a month of playing with my new toy, I decided to take some photos and post a brief description of JQ4030 laser engraver.
It might be useful.
Old 08-10-2011, 04:51 AM
The Body
As you can see on pictures the body is well made, very sturdy and heavy (app. 90kg) so it's almost vibration free.
Front door is a bit loose, but it causes no problems opening and closing.
The thing that I miss is safety switch on the cover.
Contacts on back panel are easily accessible, but I miss one more 220 jack to plug in exhaust fan. (had to do extra wiring and switch)
Control panel is soft touch and there's no big emergency stop button (too bad).
Name:	body front.jpg‎
ID:	139830   Click image for larger version
Name:	body side1.jpg‎
ID:	139831   Click image for larger version
Name:	body side2.jpg‎
ID:	139832   Click image for larger version
Name:	body back.jpg‎
Name:	body front open.jpg‎
ID:	139834   Click image for larger version
Old 08-10-2011, 05:18 AM
UPSKIRT
Let take a look inside of the machine
1. motorised up and down table is made with chinese precision, controlled by two buttons on right side of the machine, and it makes some strange noise when moving up and down (I think it's something in chinese language, that I don't understand LOL)
2. MB is installed on lower right side and it looks clean, nothing special about it.
3. Red dot is positionet just behind the head
4. The honeycomb table is boxed and it sits on a lift platform (again chinese precision)
ID:	139836   Click image for larger version
ID:	139837   Click image for larger version
ID:	139838   Click image for larger version
Old 08-10-2011, 05:28 AM
ACCESSORIES
Standard accessories are air pump, exhaust fan, water pump (hidden in the tank with distilled water) and nice toolbox.
I've also ordered rotary device, and you won't believe it works.
Only hard thing is to connect the device, because connectors are just behind Y axis rails.
ID:	139841   Click image for larger version
ID:	139843   Click image for larger version
ID:	139844   Click image for larger version
ID:	139846   Click image for larger version
Old 08-10-2011, 06:20 AM
FIRST PROBLEM AND AFTER SALE SUPPORT
Really bad issue was honeycomb table.
As you can see, honeycomb table was few cm smaller than actual work size.
And if you subtract the edge you get work size app 24x34 cm not 30x40 cm as it should be.
If you look on the smaller pic, you could see that the table is from one to the other edge. And actual work size is 30x40.
So I contacted my local agent and agent in china and after some persuasion why do I need such work size, the finally decided that they will send me a bigger table. But I will have to wait for about 2-3 months (for my local dealers first import).
So in my case after sale support from JQ was sufficient.
BTW in the mean time I have to improvise, so does anyone have some ideas how to make alternative work table.
I need to review MBG General Metalwork Discussion 15 03-07-2008 02:57 PM
HF 8 X 12 review ???? Dan S Mini Lathe 1 09-08-2004 09:57 PM
