Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-09-2011, 03:52 AM
desibrown is on a distinguished road
Angry Laser GCC Spirit
Hello guys,
I got this new problem. Laser Engraving is not balanced. Please Check attached image and suggest fast
best Regards.
Old 10-22-2011, 07:24 AM
Angry Gcc Spirit 25W issue(engraving.)
Hello Engravers Please help me out.. Please see the attached image.. Why my engraver just drops power in the middle of every engraving..
DPI500 (Increasing DPI to 1000 it does the same some areas engrave deep and some at low power)
Speed 50
power 95
ppi 400
Tell me what could be the reason. Plz..
Old 10-28-2011, 10:04 PM
bpoulin is on a distinguished road
1. Check your alignment.
2. Watch your temp while engraving, see if it fluctuates.
3. Try engraving on a different material, wood has grain, and that grain can cause problems with a smooth etching. Try MDF or something else.
4. Increasing DPI shouldn't fix this kind of problem.
Old 10-28-2011, 10:28 PM
I almost forgot the most important one, make sure the machine chassis has it's own ground wire run outside to a grounding rod.
Old 10-29-2011, 04:21 AM
Rodney Gold is on a distinguished road
Clean the rollers and rails properly and check the shaft encoders in the X and Y motor housing havent got dusty for the first picture. The 2nd picture looks like a failing tube , clean all the fans in the tube enclosure and blow all the dust off the heatsinks of the tube. how old is the tube?
Problem- Laser pro Spirit issue desibrown Laser Engraving & Cutting Machines 2 06-09-2011 10:32 AM
Need Help!- Problem with cutting on GCC Spirit RRSS79 Laser Engraving & Cutting Machines 7 05-16-2011 02:52 AM
New SLV 40 'Spirit'! What to expect? parkerbender HURCO 1 01-05-2010 07:42 AM
Need Help!- New Laser pro spirit. desibrown Laser Engraving & Cutting Machines 3 11-10-2008 02:46 PM
spirit houses charper Machine Created Art 2 10-22-2007 07:51 PM
