Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-07-2011, 08:34 AM
curious is on a distinguished road
picture engrave only lines
hi
i tryd to engrave a picture ,but the laser only engraves horizontal lines ?
it dousnt even look like a picture ?
i use lasercut 5.3
tube 180W
picture from photograv
changed W/scan gap/filled/speed.
picture of result attached
who has an idea ?
Old 09-11-2011, 08:56 AM
cinematic2 is on a distinguished road
Have you ever heard about rasters?
CNC lasers, constructions, service
Old 09-11-2011, 09:26 AM
bpoulin is on a distinguished road
post the image you are trying to etch.
Old 09-11-2011, 10:58 AM
i found the problem
it was the red high power cable what was touching the blue wire
many strange things happened with the laser ,like a poltergeist
now its working ok.
only engrave on glass is still not ok
tryd wet paper ,low dpi on wood its ok.
Old 09-11-2011, 12:21 PM
Can you post the pics of what your glass looks like after a failed etch, and the original image you want on the glass? We might be able to help you.
Old 09-12-2011, 10:00 AM
this is on the glass, as you can see there is missing detail
on wood its sligtly better
also is attached original foto before changing to b/w and photograph software
i hope some there is a way to improve the quality
ID:	141791   Click image for larger version
Old 09-12-2011, 11:24 AM
Tweakie's Avatar
Tweakie is on a distinguished road
I think this is just one of those techniques you will have to practice at to get it right. You are perhaps using too high a power level on the wood and loosing detail there but the image itself is probably not the best you could be using. Really you need to use images with high contrast ratios to get the best results and here the dog is sitting in partial shade.
I ran your image on wood and my results were not very good either.
Tweakie.
CNC is only limited by our imagination.
Old 09-12-2011, 11:27 AM
could you post an image with good contrast ?
to see the difference
Old 09-12-2011, 11:38 AM
Tweakie's Avatar
First one I came across using the same wood.
Tweakie.
Old 09-12-2011, 06:56 PM
Wow, tweakie impressive results. Given the image, I think it's the best burn you could get. I 2nd the opinion that you are using too much power. That may be the problem with the glass as well. Try using a lower power to see those results.
  #11   Ban this user!
Old 09-13-2011, 01:23 PM
its getting better ,tweaky send me a picture i lasered on glass.
from the side its looking far better than from the front.
also if i put the glass in front of another glass there is more detail.
what i wonder is ,what is the relation between thickness of the engraving line ,and the max.sharpness.
eg if the picture is too small there is no detail,increase size its getting better.
is there a calculation ?
or how is it possible to get really photo quality ?
  #12   Ban this user!
Old 09-13-2011, 10:02 PM
Work on your focus, what you think is in focus may actually be out of focus. Try this, fire your laser in test mode so you have a single dot, then manually move the laser over a step or two, then move your table up a step, and fire again, do this 5-10 time in a row, and compare the dots left, do this until you find the smallest dot, and that is your true focal point. If the dots only get bigger, return to your start point and move away from the lens.
YES there is a huge relation, think DPI on a printer, if you use an old dot matrix printer that has 12dpi vs a new inkjet that can have 700dpi or more. The difference would be obvious, the same is true for the laser, the smaller the focal point, the finer the dpi, the more detailed the picture. If you need a finer dot, you'll need to get a different focal length lens. As far as lenses go, usually one that's good for cutting is bad for engraving, and one that's good at engraving is bad at cutting.
Unfortunately if the picture is too small to start with you can't just enlarge it to gain detail. Once the image is compressed to a small size detail is permanently lost. You always need to start with the largest image possible, so you have all the detail. You can then down size the image to your needs.
Start with a high quality photo to engrave.
Dashed Lines?? Sames lines to still show dashed in different scaled viewports? coykiesaol General CAD Discussion 1 12-29-2010 09:38 AM
Need Help hooking up Viper200 Stop-Out lines to CNC4PC C1 BOB Input Lines CNC-Joe Viper Servo drives 1 08-11-2010 07:59 AM
Newbie- I want to learn how to engrave. kasari WoodWorking 4 02-28-2010 08:46 AM
how to engrave cob Mastercam 27 10-17-2008 02:51 PM
picture engrave meirmark WoodWorking 1 09-18-2007 09:31 AM
