Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-03-2011, 06:24 AM
Pater G. is on a distinguished road
JQ LASER CUTTING SPEED
HI!
I'm proud new owner of JQ4030 60W.
It's realy sturdy build machine, but with some chinese leaks.
(They realy don't give to much on accuracy)
It was almost plug and play, so about that I have no complaints.
The mirrors were aligned and works almost fine.
But there's a problem that I cant solve:
Cutting Speed: When I set cutting speed above 9mm/s Laser head moves arround, but laser just don't fire and the power meter is idle.
I suppose that is somekind of software setting issue.
Please can anyone help me out.
Old 08-04-2011, 01:32 AM
PROBLEM SOLVED!
HAD TO REINSTALL THE SOFTWARE.
HE HE
Cost effective metal laser cutting solution: YAG metal laser cutting machine hanzlaser Trade Shows and Events 1 08-04-2011 04:00 AM
Cutting speed locked to Z torch height control speed Beefy Mach Plasma / Laser 1 02-14-2010 05:14 PM
Is cutting speed limited to Z-axis speed Beefy CNC Plasma and Waterjet Machines 4 02-13-2010 04:06 PM
Newbie- Co2 Laser cutting guide or PDF for different power settings and speed WooDe Laser Engraving & Cutting Machines 8 10-07-2008 03:24 PM
80W Laser 3/4" Plywood cutting speed coleclan Laser Engraving & Cutting Machines 6 12-18-2007 12:49 PM
