Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 08-02-2011, 11:04 AM
WastedHippy is on a distinguished road
Newbie with LS3020
Hi Folks
Just ordered an LS3020 and have what will probably be the 1st of many dumb questions while learning the ropes over the next week or so.
I've been working with Photoshop for years and although not familiar with Vectors and Rastors I'm fairly on the ball with the software so a few other functions shouldn't tax the brain too much. Is it best to stick with Photoshop being I know that reasonably well or learn to use CorelDraw.
Water do I need distilled or regular tap water, sure I've seen both mentioned.
I've ordered a few sheets of 1.5mm engraving laminate to mess about with, initially just looking to do text and cutting squares to keep things basic to start with.
Thanks in advance
Paul
Old 08-02-2011, 11:14 AM
chadlad84 is on a distinguished road
Industrial lasers use de-ionised or distilled water in the cooling system.
I guess normal water would leave deposits of scale inside the system. Although you may be able to get something to treat normal water. Not sure
Hope this helps. :-)
Old 08-03-2011, 03:26 AM
geekinesis is on a distinguished road
Photoshop wont work. It has to be a vector drawing programme that outputs dxf files like coreldraw or inkscape etc
And it has to be distilled water (from a chemist in the uk usually) otherwise the impurities will affect the components the laser tube.
Originally Posted by WastedHippy View Post
Hi Folks
Thanks in advance
Paul
rabbit / ls3040
LS3020 ENGRAVING PROBLEM. ru-alright Laser Engraving & Cutting Machines 1 06-23-2011 05:46 AM
Need Help!- LS3020 Perspex Edges fullingdale Laser Engraving & Cutting Machines 3 06-22-2011 06:31 PM
HPC LS3020 LASER + 3mm ACRYLIC PROBLEM ru-alright Laser Engraving & Cutting Machines 5 06-15-2011 04:50 PM
Diy CNC newbie ? gumush Parts for Radio Control Models 0 10-08-2010 04:04 AM
help with ls3020 shellglen69 Laser Engraving & Cutting Machines 4 06-02-2010 07:35 AM
