Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 07-31-2011, 03:24 AM
JP777 is on a distinguished road
Rabitt HX40B out of order
Hello,
I am French and do not speak English, also be indulgent with the automatic translator.
Rabitt HX40B does not want to engrave and to cut.
Card controleur and card high voltage = new. Tube = new. Software = newlydraw.
If I draw a rectangle, the machine follows the plan but does not cut.
If I use the bouttons of test of the laser, the machine follows the plan and cut. I can increase or reduce the power.
Help me!!!
Thank you in advance.
JP
Newbie- problem with rabbit HX40B JP777 Laser Engraving & Cutting Machines 1 07-30-2011 03:17 AM
Newbie- HX40B - what are the best settings shazz Laser Engraving & Cutting Machines 3 03-29-2011 07:57 AM
Stubborn HX40B jencen Laser Engraving & Cutting Machines 15 05-19-2010 03:05 AM
Need Help!- hx40b nazirabd Laser Engraving & Cutting Machines 7 05-19-2010 02:38 AM
HX40B to MACH3 austin.mn Laser Engraving & Cutting Machines 10 02-22-2010 12:49 PM
