Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 07-23-2011, 10:46 AM
michael lepage is on a distinguished road
Question moshidraw laser sh-k40 IV
Hello,
I foresee it Here I am Belgian and French so I translate my posts by our friend Google
I bought a Chinese laser Shenhui laser SH-40K IV moshidraw (software and driver).
But here it has never worked properly.
On vista I have always the error: error data conversion
On XP it serious part and then it stops, not simple.
So here as the laser engraver is equipped with a USB key protection and I can not use other software and driver Moshidraw.
I read in this forum that it was possible to change the card to use another driver and other software,
can you tell me if it is easy to use and install?
And the price may
In addition there is a possibility of assistance in French?
All the information is useful.
A big thank you to all. :
Old 07-25-2011, 09:34 AM
hello,
So it is with a laser USB
The manipulation to change the control board is simple?
and what card should I take?
and what is the price (+ -) or order this map?
a big thank you for your reply
Old 07-25-2011, 09:41 AM
ok thank you very much
Old 07-25-2011, 04:57 PM
Salva Blasco is on a distinguished road
Moshy
Moshy software is used in chinese market, no link witht corel or others.
Old 07-28-2011, 10:01 PM
Jack Jia is on a distinguished road
hello, i am also buyed laser machine which has this problem, but the supplier has solve it for me, you can contact this supplier:Yufeng, may be he can help you. he give me so much help
his Msn :jinqianglaser32@live.cn
Old 08-01-2011, 04:30 PM
Machado3 is on a distinguished road
My friends, download the last version of Moshi here http://www.moshisoft.com/soft/moshidraw_left.exe. To link with Corel Draw, you should install the Corel completely, and in Moshi software go to File > Options and Link do Corel Draw, ok.
Old 09-25-2011, 07:51 AM
dontseme is on a distinguished road
I also have this laser. I cannot get the laser to engrave. I have tested the alignment of it and when you hit the test switch the it is fine. But when Moshidraw goes to engrave it acts like it is engraving (you can see the tube flickering) and the engraving head moves but no laser comming out if it. Any ideas?
Old 09-25-2011, 10:22 PM
Cat cat is on a distinguished road
We use Newlydraw for our mini desktop laser machine
Old 09-26-2011, 03:00 AM
pyrocrafter is on a distinguished road
I use Moshidraw and DC-K401V Shenhui laser engraver. I presume you have the correct setting on the software for the type of engraving you want to do. On the output page, mine is set to 'Cave' (presume this is meant to be Carve) and 'Normal' for engraving wording or pictures on to wood, plastic or leather.
Try turning up the mA current whilst it is engraving, a spark should be emitting from the laser and will get stronger the higher it is set. Mine is set to only 3mA for engraving on leather but it needs to be higher for cutting.
Hope this is some help.
Need Help!- CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser vksingh Laser Engraving & Cutting Machines 2 07-01-2011 10:52 PM
Laser Cutter Engraving CO2 Universal Laser System CNCadmin EBAY ADS 0 05-07-2011 11:20 PM
Cost-effectective 445nm laser for laser show cni Product Announcements & Manufacturer News 0 12-20-2010 01:01 AM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
