| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I am looking for a suitable laser head that will cut through 1/2" plywood ( Italian Polar and Baltic Birch ) What amount of power do you recommend and are there any brands of laser heads I should consider/avoid? Yes, I know I will have charred edges, that's of no concern. I also have compressed air, a means of removing smoke and CO2 if necessary. |
| 100W would be marginal and depends on the epoxy (glue) and other resins in the wood, so I would suggest 120W+ (this is based on Chinese glass tube CO2 lasers). If you are considering a higher end machine, with something like the Synrad RF excited metal tube laser you would be ok with 80W+. You can usually trade speed for cut depth, or use multi-pass but as you already know this isn't ideal on wood and will result in very charred edges. If you are going to be doing mainly 1/2" and above, a 400W+ system would be recommended. Zax. |
| When I was at shenui laser in China , I saw they had dual laser systems for cutting and manufacturing thick die board , there are 2 x 150w glass tubed lasers , one firing at the top and the other at the bottom of the boards , these would be ideal for cutting 1/2" plywood imo. |
| What is their quality, reputation etc like? |
| Excellent machines , excellent service , excellent tech support. Read my threads... Chinese lasers - they're here !!!!!! and Despatches from China on further reflection I think the dual up and down firing lasers might not be ideal for cutting , they were lasering die board, dunno what would happen to the cut piece.... |
I am going up to China to buy some machinery for the company I work for so I just might visit these guys and see what they have to offer. Cheers |
| Just as a point of reference, I just got a 80W CO2 laser, I can cut 1/2" solid pine no problem, but I can barely cut the 1/4" plywood I got at the same speed. I think it's because it's "Exterior" plywood, if you look at the edge, you can see black layers of glue. I'm looking for some other types with less glue / coatings, under the theory that they'll cut better. |
| New Machine Build- 50" x 100" Plywood gantry router | Yehuda | Open Source CNC Machine Designs | 9 | 10-04-2011 03:07 PM |
| cutting plywood w/ a laser | sthole | WoodWorking | 3 | 09-13-2011 03:38 AM |
| Need Help!- Alternative to "laser" branded plywood? | Solexious | Laser Engraving & Cutting Machines | 3 | 11-27-2010 06:52 PM |
| UK Laser plywood supplier? | KPBadger | Laser Engraving & Cutting Machines | 2 | 02-26-2010 10:25 AM |
| 80W Laser 3/4" Plywood cutting speed | coleclan | Laser Engraving & Cutting Machines | 6 | 12-18-2007 12:49 PM |
