Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 07-02-2011, 05:10 AM
chippypah is on a distinguished road
Laser power
Hi All,
Just got my upgrade 100 watt tube and power supply, from Coletech but the power supply is not working.
Can you run a 100 watt tube from a 60 watt power supply without doing any damage to the tube ?.
Cheers
Pete
Old 07-04-2011, 05:14 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Pete,
You won't damage the tube by trying but it is doubtful that the 60W psu has a high enough striking voltage for the longer 100W tube so it just may not work.
Tweakie.
CNC is only limited by our imagination.
Old 07-04-2011, 05:36 AM
Rodney Gold is on a distinguished road
Check the fuse in your new power supply , it might just be that that is blown.
Old 07-04-2011, 06:47 AM
Thanks for the reply's, checked the fuse and it is OK.
Cheers
Pete
Old 07-06-2011, 10:43 AM
zax15uk is on a distinguished road
The PSU may not be wired correctly, depending on your model the interlock and/or laser enable circuits need to be grounded or held at correct input.
Zax.
Old 07-06-2011, 10:49 AM
Wired as per these instructions.
Cheers
Pete
Old 07-11-2011, 08:46 PM
xzoom is on a distinguished road
HELLO
ABOUT USING A 40W TUBE ON A 50W MACHINE?
40 W TUBES ARE CONSIDERABLE CHEAPER THAN 50W
Old 07-16-2011, 03:09 AM
nick81 is on a distinguished road
You will find that some laser tubes that have a SEPERATE exciter / RF unit must be tuned (or matched) to each-other. Connecting un-matched RF unit and CO2 tube can damage the tube.
If it is all one unit (RF and CO2 tube in the one package) usually it is only power supplies / mainboard / firmware required to upgrade. But it is very messy and you'll probably struggle with it. Trade in your old laser on a new one - my advice!
Old 08-08-2011, 02:02 PM
cinematic2 is on a distinguished road
Man, wake up!
They are talking about CW glass lasers, not RRF lasers.
CNC lasers, constructions, service
Old 08-08-2011, 02:03 PM
Man, wake up!
They are talking about CW glass lasers, not RF lasers.
Problem- PWM laser power geekinesis Laser Engraving & Cutting Machines 0 02-15-2011 07:47 AM
Laser Power apeman88 Laser Engraving & Cutting Machines 11 02-01-2011 11:40 PM
CO2 Laser Power Dubliner Laser Engraving & Cutting Machines 3 11-01-2010 12:28 PM
Problem- no power to laser? KPBadger Laser Engraving & Cutting Machines 10 02-22-2009 11:35 PM
Cnc low power laser bushmac CNCzone Club House 0 01-31-2009 12:15 PM
