Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-30-2011, 01:18 PM
rustyolddo is on a distinguished road
Any DIY YAG/Fiber lasers?
Need something that can engrave metal similar to electro etching. It's not cost effective nor easy to make stencils for one-of jobs. Currently using a high speed spindle and I've used a vibratory engraver in a CNC application.
I see a number of fiber laser diodes listed on Ebay. What would be ideal, and I don't know if such an animal exists, would be a laser device where the head was connected to the laser via fiber. The head would be mounted in place of the CNC spindle and you would drive the machine using regular CAM software using M codes and Z retracts to turn the laser on & off.
Is something like this possible and cost effective using surplus parts?
Old 07-01-2011, 08:13 AM
Tweakie's Avatar
Tweakie is on a distinguished road
If you already have the CNC then it is quite feasable to do and not that expensive I would think. You need a laser operating around the 1064nm range for marking metals and you also need to be clear on the various terminology formats. Fiber lasers are typically beyond the financial reach of the home constructor but diode lasers which are connected with a fiber optics beam delivery system are relatively cheap. The YAG stuff is also cheap but tends to be large in size and the triggering components (Q switch etc.) quite complicated to use so the diode is probably the best bet.
I fitted a CO2 laser head to my existing CNC (no good for marking metals, wrong wavelength) quite a lot of work but brilliant now it is all working Tweakie.CNC - CO2 Laser Cutting.
Tweakie.
CNC is only limited by our imagination.
Old 07-01-2011, 12:09 PM
Originally Posted by Tweakie View Post
... diode lasers which are connected with a fiber optics beam delivery system are relatively cheap. The YAG stuff is also cheap but tends to be large in size and the triggering components (Q switch etc.) quite complicated to use so the diode is probably the best bet.
Tweakie.
Thanks for the link to your website, very informative especially the discussion on how you used the Z direction pin to control the laser. I have two bench top machines that I converted & run Mach3 on including a 4th axis. My biggest lack of knowledge is in the laser field. Especially when it comes to the diode types & what needed to drive them & the optics. Power supplies are no problem, I've built many. I understand I need 1064nm for metal, a lot of the diode lasers with a fiber optic are in the 808nm range. I need to keep digging on this subject.
I think in the mean time, I might have a go at the low power LED laser, it would be handy for making the occasional gasket, never gave it much thought until I saw your application.
--R
Old 07-02-2011, 12:30 AM
Tweakie's Avatar
Rusty,
For the low power laser you need at least 150mW (more preferably) and even then you will be very limited in material thickness that can be cut but it's a fun project and lots to learn.
Make sure you wear the appropriate eye protection (the beam bounces off just about everything).
Tweakie.
Old 07-02-2011, 11:44 AM
mcphill is on a distinguished road
The YAG stuff is also cheap ...
Can you possibly share some sources? Or what do you consider "cheap"?
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
Old 07-02-2011, 12:20 PM
Tweakie's Avatar
You perhaps need to check with ebay in your own country on a daily basis to see what comes up, the real bargains don't last long.
In the UK something like this is perhaps worth a shot YAG LASER FOR CNC | eBay UK
Unfortunately everybody's definition of "cheap" will be different - for me it is something that I can afford (hundreds rather than thousands).
Tweakie.
Need Help!- Lasers goldwing199 General Metalwork Discussion 6 05-11-2011 09:03 PM
Lasers LeonD DynaTorch 6 11-25-2009 01:42 PM
New to lasers 918rbennett CNCzone Club House 4 09-23-2009 07:31 PM
Lasers Appalachiatools General Electronics Discussion 5 05-05-2009 05:39 AM
Fiber Lasers, any future for hobbyists? blurrycustoms Laser Engraving & Cutting Machines 11 12-17-2008 05:35 AM
