Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-29-2011, 01:42 PM
rcpilot82 is on a distinguished road
DIY 4th Axis for laser
I am wanting to build a rotary 4th axis for my Rabbit laser. Has anyone out there made one? Since laser 4th axis are light duty (no tool pressure) I would think an accurate axis could be built fairly easy and for alot less than what they are sold for. I am working on some sketches but wanted to see what has been done by others.
Necessity is the mother of all invention (unknown)
My club home page www.lhmac.org
Old 06-29-2011, 01:56 PM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Ive seen laser 4th axis that were merely 2 rubber wheels with some sort of encoder for doing round objects. Ie bottles just set on top of it.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 06-29-2011, 02:53 PM
I was planning on doing a roller setup as most of the things I would use this for would be better in a roller setup. I figured someone had done this before and could maybe save me the "design" time.
Old 06-30-2011, 10:19 AM
I guess i will have to continue on with my design. I will be making it from acrylic since there is no real load other than the weight of the object being engraved. I am also thinking about making a reversable drive assembly so that one end has rollers and the other end has a chuck.
Old 06-30-2011, 11:37 AM
miljnor's Avatar
S.N.A.F.U.
If i was making one and not concerned with loading time, because its not for a production deal I would definitely use a chuck of some sort so I could do NON-round parts.
or do both and call it good.
but this is only a hobby for me. I use real machines at work.
thanks
Michael T.
Old 06-30-2011, 12:02 PM
This is not for high quantity parts, just messin around and some side stuff to support my hobbies. I am looking into how I want to approach the double sided drive end.
Lol, this started so I could make my own RC Airplane kits and is complimented by my router. It has turned from a hobby to an obsession and a side buisness.
Old 07-03-2011, 12:09 PM
miljnor's Avatar
S.N.A.F.U.
Ya I started a laser cutter for the same reasons....its still in the build stage because I had a business failure for a couple of years....now im starting back on it.
build some RC plane stuff and if someone asks I'll sell some too!
good times
thanks
Michael T.
Tags
4th, axis, diy, laser, rotary
5-axis laser software smessi General CNC (Mill and Lathe) Control Software (NC) 0 07-14-2009 04:56 PM
Laser Engraving Retro - on a 3-axis Mill? joecomunale Laser Engraving & Cutting Machines 0 12-25-2006 10:52 PM
Five Axis Laser Operator Needed fireman_1977 Employment Opportunity 0 06-23-2006 10:16 PM
Cool cnc videos, laser and 5 axis DennisCNC CNCzone Club House 2 10-06-2005 09:07 PM
