Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-24-2011, 06:18 PM
starlight is on a distinguished road
Laser will not fire
I have a Chines laser that will not fire. Its about 3 years old, used it last weekend and worked OK. Water is flowing and the laser head is moving. Is there a troubleshooting guide out ther someplace. To check the water flow, Power suppley, something to get started out how to find trouble. Thanks
Old 06-24-2011, 06:25 PM
lrob is on a distinguished road
I would start by checking the door switch. If it is not working, the laser will not fire.
Old 06-24-2011, 08:45 PM
kofi_sunic is on a distinguished road
Procedure for checking
1. Check the focal length : readjust the focus
2. Check the focus lens : make it clean
3. Check the light path : adjust the light path
4. Check the other reflectors : make them clean
5. Check the water circulation : make it circle
6. Check the temperature of the water : make the water not so hot
May this will help you.
Old 06-24-2011, 08:55 PM
Rodney Gold is on a distinguished road
Check the parameters like speed and power of the file you are sending is correct and they the item is being output
If you have a laser button on the machine control panel that allows firing independantly of the computer and this doesnt work then:
check the water flow sensor if you have one
check any safety interlock switches (like the aforementioned door switch)
Check the power supply fuse is still ok (inside the powersupply box) ,if the powersuppy box has a fan and its not working , then the fuse is probably blown
check the power supply is working and hasnt popped a component
check the tube and all wiring to it
Check the motherboard wiring to the laser
If you can actualy see the tube fire inside the tube but get no output at the laser head , check the optic path
Old 06-28-2011, 11:54 PM
CNARTSIGN is on a distinguished road
Old 07-09-2011, 10:53 AM
Laser not firing
Thanks for the info on this. I have been out of town a few days. The power supply has 2 red lights on it, when laser is turned on both lights are on dim, if you open a door thay go out, if you unplug the water thay go out, so I think that looks like switches and water flow is OK. when I run a cut file the red lights on the power supply go bright red but the tube does not fire, at the end of the tube were the power goes in it looks like it get light but does not fire. If the line that comes out of the power supply is close to the metal it sparks, It looks good, no cuts were the power should be coming from. Move the line from the metal and it still does not work so I don't think the line is broken. I don't know were to go from here, I have emailed a few of the people on ebay that sells tubes and power supply, but its been over a week and no come back so I don't know were I can get parts even if I can find out whats wrong. Thanks Dan
Old 07-09-2011, 05:07 PM
fullspeceng is on a distinguished road
Unplug the 6 pin green plug out of the power supply and press the black test button. When your laser fires the tube turns pink. If it still doesn't fire then your laser tube is bad. If it does fire then likely your control card power output DAC is bad.
We can sell you whatever parts you need out of Las Vegas, NV, USA.
Visit our website at Home page
fire clay/fire rock banctecbobn Casting Metals 10 12-12-2009 04:14 PM
no laser fire at low power setting bgirit Laser Engraving & Cutting Machines 11 09-18-2008 07:38 PM
Need Help!- Laser won't fire CARTOGATE Laser Engraving & Cutting Machines 3 08-25-2008 02:22 AM
using gas to stop fire on 3040 laser? StarLoc Laser Engraving & Cutting Machines 0 06-25-2008 01:20 PM
Smoke and fire...yes FIRE! fatal-exception Gecko Drives 13 01-25-2008 01:58 PM
