Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-22-2011, 09:11 PM
moraus is on a distinguished road
What equipment to engrave Hip Flasks
Hey all new to this site but fantastic infromation. Any how i am a bit lost with what equipment i need. I want to do some on the the side engraving and laser printing but not use what i need. i am looking at doing hip flasks etc So the material is stainless steel. I have looked at the laser engraving but they seem to be light and only good for non metal prioducts. Any suggestions would be great. Attached is the sort of finish i am after.
Regards
james
ID:	136962   Click image for larger version
Old 06-23-2011, 12:03 AM
Rodney Gold is on a distinguished road
You can use any Co2 laser to do that , you coat the stainless steel or metal with a product called Cerdec andf you laser it and it makes a permanent black mark. Works real well.
Old 06-24-2011, 02:55 AM
kofi_sunic is on a distinguished road
YAG/Diode laser can engraving stainless steel
If you want to engrave on stainless steel, you can use YAG laser marking or Diode pump laser marking machine. But not too deep, 0.5mm depth.
I just engraved on a stainless steel and took a video. You can give me your email address, i'll send it to you
Old 06-25-2011, 12:29 AM
muqtadir is on a distinguished road
Kofi
What is the price for YAG/Diode laser can engraving stainless steel ?
Can u send me more information at muqtadirkhan@yahoo.com
Old 06-25-2011, 12:46 AM
Originally Posted by muqtadir View Post
Kofi
I've sent it to you, pls check it.
Old 06-30-2011, 09:38 AM
rustyolddo is on a distinguished road
I'd like some information on this as well. Actually, what I would really like to know is if there is some kind of YAG/Fiber laser that I could build/adapt to my existing CNC machine. Basically a laser head that could be held by the spindle and controlled with M codes or in a similar manner.
Old 08-08-2011, 03:28 PM
LaserSharp is on a distinguished road
A few possibilities.
A galvo driven laser head can do the marking within a fixed window, e.g. a f160 lens can mark a 4.33" sq area. A f254 can mark a 7.86" sq area. If the part to be marked is under that, you will only need to use the spindle adaptor for the initial X-Y locating.
If you have a fixture with many parts to be marked, lets say 30 parts in a 24" x 48" fixture, you can use the same marking file with different X-Y spindle locations for the start of each mark.
If you are thinking of a static mounted beam and utilizing the X-Y motion of the spindle to actually engrave, I don't believe that will work. For metal cutting, the depth and speed is relatively not all that critical.
To mark a graphic design or font is much more difficult. The laser must be switched off between each movement and restarted (and delayed) a fraction of a second as the head changes direction to prevent burn-through. Fill percentage, mark speed, frequency and power level all change with each stroke to obtain the even finish you get from a great laser mark.
As well, the galvos move at incredible speeds to accomplish their work. Virtually all design or engraving work is accomplished with a galvo driven head. The units I have seen in operation have a fairly small head (8"H x 6"W x 15"L) and mount with a standard bracket attached with four M8 screws. The umbilic attaches to the head and just needs to be supported and not kinked.
I hope this helps... Don't forget you need a class 1 enclosure and special glass in your CNC or 1064n glasses in an enclosed room.
Old 12-06-2011, 01:51 AM
Rodney Gold
How we can calculate for cutting by Co2 laser machine of 60 Watt per hour ?
For example If we run our machine for 5 hours per day for 2 mm thick MDF and take about 1 hour a job. As I calculate the price of laser tube approx. 300$ and life is 1000 hours. It means per hour is 0.3 $. Is this correct or what is the correct formula for a job for cutting.
Thanks.
Newbie- I want to learn how to engrave. kasari WoodWorking 4 02-28-2010 08:46 AM
how to engrave cob Mastercam 27 10-17-2008 02:51 PM
What is Grade Engrave? SkipW Laser Engraving & Cutting Machines 2 10-23-2007 04:10 PM
Need to engrave on a sphere carbidecraters BobCad-Cam 42 07-29-2006 08:02 AM
New Flasks and molding bench - web posting FrankG Moldmaking 0 01-13-2005 10:35 PM
