Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-14-2011, 06:44 AM
madridi007 is on a distinguished road
Exclamation plz plz help me
I have a problem in software of Laser Engraving & Cutting Machines machine model CMA-1080K
i have this machine from HAN'S YUEMING LASER TECH CO
Z-axis only working for the contoller and the other is not work l, and laser control does not work too brecause machine software
how i reprogramming the motherboard (no2) of machine
Please detailed explanation of why, because I don't have sufficient information about the machine and method of control
How can access to the internal RAM of the machine to know what programs are available
plz answer me and tell me if any one in this forum have the same machine which i have
Old 06-14-2011, 08:29 AM
KPBadger is on a distinguished road
MPC6515
Hello - does the machine use this control card?
see attached .pdf
regards
KPB
Old 06-14-2011, 08:56 AM
not this control card
it use this card in attachment
Name:	NO2 motherboard.jpg‎
ID:	136369   Click image for larger version
Name:	components of NO2 control panel.JPG‎
ID:	136370   Click image for larger version
Name:	control panel.JPG‎
Old 06-14-2011, 09:06 AM
NO2 board.
Hello,
sorry i dont know about that one, but you should ask HAN'S YUEMING LASER TECH CO. if they have a data sheet / manual for the control card.
It should be possible to re-flash it with the original firmware ?
you might be able to download the firmware from the manufacturer of the card.
(though maybe you will need to learn reading chinese! )
Good luck!
hopefully someone who knows this card will reply.
KPB
Old 06-14-2011, 09:55 AM
thank you
any one can help me plz
