| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I'm frustrated that the cutting area of laser machines is so small. So I wanted to ask, what are the factors limiting the expansion of the cutting area? I'm just guessing, as I have just started learning about laser cutters, that it is related to: total linear distance the laser is traveling or laser power frame tolerances impacting laser alignment I have looked at the laser build 2.x and full spectrum's lasers. Ideally I would want to build a laser cutter with a cutting area of 48" x 48". Is that possible. Perhaps just adapting the 2.x build, modifying the frame, perhaps using larger profile extrusions and motors? Thanks for the physics lesson forum people. |
| You will find that in most likelyhood the issues you will faced is loss of power as the beam has to travel further and trying to maintain a very close tolerance with respect to the laser head to table/workpiece distance. If you didnt use a flying head system and had a laser mounted directly to the y axis cross beam that traverses across , you would have less issues... but it would be real slow to engrave and to cut. |
| How do I know what linear distance a beam of a given power can travel? 40W? 60W? Is this really not about power, but rather beam spread? How is beam spread controlled on larger machines? Mounting the tube to the gantry shorten linear distance and makes alignment easier. What are the drawbacks to this approach? |
Any information I can find I'll contribute to the thread. I've actually considered buying a laser and performing some experiments. |
| Hi All, Mine is 6 feet square... buildlog.net • View topic - 20 Years in the Making... Works great at any position. Tim |
| Factors affecting accuracy in hot wire CNC's? | SkyG | CNC Wire Foam Cutter Machines | 3 | 11-28-2011 06:04 PM |
| Need Help!- ez trak program size limit? | Mikael! | Bridgeport and Hardinge Mills | 7 | 03-05-2011 10:50 AM |
| Need Help!- why? CAM For machine Limit size G-Code 130kB. | pnpdesign | Okuma | 4 | 07-13-2009 03:22 AM |
| File size limit??? Dripfeed?? | jsatter | AjaxCNC Control Products | 8 | 01-31-2007 11:22 AM |
| program size limit | stevieboy | General CNC (Mill and Lathe) Control Software (NC) | 2 | 08-17-2006 02:23 PM |
