Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-08-2011, 12:36 AM
laserdes is on a distinguished road
Engraving banding after new tube install
I installed a replacement tube in my 40 watt laser engraver last week. It seems to perform well when cutting and I'm back to using speed and power settings comparable to what worked with my old tube when it was relatively new.
There is a problem with engraving though. Compared to my prior tube in its earlier days a lot more power is required and the final appearance is irregular with obvious banding. I'm using the the same image preparation technique and settings that gave me good results with the old tube.
Could improper alignment be the cause of the problem?
Old 06-08-2011, 11:16 AM
Tweakie's Avatar
Tweakie is on a distinguished road
I would suggest that you check the alignment. The procedure is quite simple but it can take some time to get it spot-on.
Tweakie.
CNC is only limited by our imagination.
Old 06-08-2011, 11:27 AM
Tweakie's Avatar
One extra thought.
If you are unlucky enough to have a machine where the mirrors are bolted together then it may be good to take some time to radius the ends of the adjusting screws and fit small compression springs (see pic).
It makes alignment and adjustment soooo much easier.
Tweakie.
Newbie- tube endforming equipment for telescoping tube DanP Want To Buy...Need help! 2 01-23-2012 04:32 AM
Banding problem when engraving acrylic shatterjack Laser Engraving & Cutting Machines 1 04-09-2011 10:59 AM
Need Help!- Edge Banding Problem Help Pls...!! kedkem Glass, Plastic and Stone 0 03-11-2011 06:22 AM
Newbie- Tube cutting; tin slots and tube ends marineboy CNC Plasma and Waterjet Machines 0 10-13-2009 04:03 PM
Need Help!- Please Help!! How to install a Laser Engraving Machine??? essa659 Laser Engraving & Cutting Machines 3 03-10-2008 05:32 PM
