Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 06-04-2011, 05:19 PM
desibrown is on a distinguished road
Laser pro Spirit issue
I was engraving some keychains and after some engraving the head hit the right side and gave error x motor malfunction. I asked GCC they said the flat cable my be the error or the mother board or x motor. I have changed the motor and board but now when I turn on the machine I get X motor malfunction error I have change the flat cable from board to x motor but still the error exists.
help me out guys.
Regards
Desibrown.
Old 06-08-2011, 09:12 PM
SteveinGB is on a distinguished road
Make sure you have the flat ribbon seeted in the rectangle on both the X Motor PCB (green board under X Motor) and Main Board.
There is the white connection box and there is a small cap at the top that has to be raised to insert / release the flat ribbon. Make sure after inserting to push down or your connection may be loose.
Blue side of flat ribbon faces the work area at the main board connection, believe it is the same at the X Motor PCB as well.
May also have a broken circuit on the X Motor PCB
Good Luck!
Old 06-09-2011, 10:32 AM
Rodney Gold is on a distinguished road
Check your limit switches are working and as the previous poster said , check the small circuit board of the X motor.
Try this as well , move the head all the way to the bottom right of the bed and reboot from there.
Laser thickness issue wickedboysap Laser Engraving & Cutting Machines 10 03-01-2011 02:06 AM
Laser Issue Ridwan Laser Engraving & Cutting Machines 3 11-01-2010 10:53 AM
Still trying to resolve a laser movement issue vsystems Laser Engraving & Cutting Machines 19 04-09-2010 03:25 AM
Need Help!- New Laser pro spirit. desibrown Laser Engraving & Cutting Machines 3 11-10-2008 02:46 PM
spirit houses charper Machine Created Art 2 10-22-2007 07:51 PM
