Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 05-19-2011, 11:24 AM
archicat is on a distinguished road
HELP - FILES NOT APS ETHOS
I've been working on drawings to get a model lasercut. However I work on Microstation (another CAD program) and export to dwg afterwards but when I went to get lasercutting done the files were all messed up with lines everywhere, they look fine in autoCAD to view but then on lasercutter the lines are all over the place. After and suggestions from lasercutter I messed with files more:
Units changed.
Coordinates changed to 0,0
Overkill to erase duplicated lines
Flatten
Export to DXF.
However it STILL wont work! Can anyone help please? I'm in my final year/week of architecture and really need to get this done. The software they use is APS - Ethos if that helps at all.
Thanks,
Cathryn
Need Help!- How can I convert .nc files into .nci files AlphaD Mastercam 8 07-18-2009 11:28 PM
Need Help!- How can I convert .nc files into .nci files AlphaD Fanuc 2 07-08-2009 01:45 PM
Need Help!- Convert files to Inventor files. bartL Autodesk Software (Autocad, Inventor etc) 7 02-03-2009 11:38 PM
convert .dnc files to .plt files. feraldave General CAM Discussion 1 10-13-2008 04:48 AM
Converting Illustrator files to Gcode files acoop101 General Metal Working Machines 1 06-05-2008 03:53 PM
