Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 05-18-2011, 04:06 PM
vee1982 is on a distinguished road
Question about Yag dpps 75w laser
Ive got a question for you guys ,
Im planning to engrave/mark hardcoat anodized aluminum , is 75w yag laser going to be sufficient to produce a nice bright logo on black anodized aluminum ?
Veetek
Old 05-18-2011, 11:20 PM
Litografa's Avatar
Litografa is on a distinguished road
More than enough
Old 05-19-2011, 12:40 AM
Rodney Gold is on a distinguished road
Why use a YAg? a simple 20w co2 Galvo will do for anodised aluminium, a YAG will actually burn away the anodising cutting into the aluminium and exposing bare metal that can corrode , a c02 will leach the black dye from the anodising and actually leave the anodising intact
Ask whoever is supplying your machine to do test samples so you know you arent buying the wrong/much more expensive type...
Old 05-20-2011, 03:59 PM
Well , yes I was thinking about the co2 laser but my customer would like to get a brilliant white engraving on class III hardcoat anodized alu. Just making sure that 75 dpss yag is enough to go thru the hard anodize
Question about laser power: Lasertag Laser Engraving & Cutting Machines 4 04-12-2011 04:22 AM
ULS 6.60 laser question??? KustomKoncepts Laser Engraving & Cutting Machines 10 11-08-2008 01:54 PM
M-500 Laser Question ebrandt Laser Engraving & Cutting Machines 1 10-04-2007 06:10 PM
co2 laser question CNCadmin Laser Engraving & Cutting Machines 5 11-10-2006 12:39 PM
Laser question watzmann Laser Engraving & Cutting Machines 4 05-02-2006 11:21 AM
