| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I am in the process of designing my own laser cutter and i was chasing information on common feed rates for different laser power. At the moment i am considering an 80W chinese CO2 laser. Can anyone give me a rough idea on the feed rates for some of these matterials:
I imagine that the thicker acrlics could be quite slow but fabrics would cut very quickly. Does anyone have experience with these. |
| If you plan to engrave (raster) it will be important to keep the inertia down, as you will want fast speeds in the scanning direction. I would recommend at least 100mm/s (~250ipm) for both axis, and if you plan to do much engraving I would double it for the scanning axis. On the slow speed end for thicker vector cutting you will want to be able to run at slow speeds, target 2mm/s. Your actual cutting / engraving speeds will vary depending on the material and power it can take without excess damage - but the above should give you some idea of parameters. I am sure Tweakie will have some good advice, and check out Bart's forum (buildlog.net - CNC Laser Buildlogs). Zax. |
| 200mmSec doesnt sound too bad. I was planning on a maximum speed of 1000mmSec+ I am considering a fairly large build at 2X1.5M with ball screws and servo drives. Hopefully that should give me the power and precision i want. |
| Tags |
| acrylic, fabric, feed rate, laser, mms |
| MDF Feed Rates? | clamps | DIY-CNC Router Table Machines | 10 | 12-28-2009 10:47 PM |
| Feed rates | jwest | DIY-CNC Router Table Machines | 1 | 11-26-2008 08:35 AM |
| Feed rates & IPM | ChristopherWood | WoodWorking | 6 | 10-30-2006 03:08 PM |
| Feed Rates | rcheli | Benchtop Machines | 0 | 12-28-2005 10:34 AM |
| Rpm and Feed Rates | Xeno | General CAM Discussion | 35 | 02-23-2004 04:06 PM |
