Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 05-03-2011, 02:59 AM
Lazgrav is on a distinguished road
Engraving on metal with paste
Hello, everyone - my first post here
I have problems with engraving on metal with paste. We are trying to get big order and now produce tests. Engraving is on wood working tools, made from Chrome-Vanadium Steel. First of all we have tried Cermark, but results were very bad - see picture 1. The problem is "dirty clouds" after engraving.
After we have tried Litoscript. It works better but still SOMETIMES small "dirty clouds" appear. And it's happened suddenly, we can engrave 3-4 tools without problem, but on next engraving can see problems - see picture 2.
Surface was cleaned very carefully.
May be here is peoples famliar with Metal Physics or Chemistry who can explained process?
ID:	133206   Click image for larger version
Old 05-03-2011, 03:50 AM
Tweakie's Avatar
Tweakie is on a distinguished road
If you are spraying the Cermark then It may be a good idea to fit a better water / oil separator and filter to your air line.
Just a thought but those patches look very much like contamination.
Tweakie.
CNC is only limited by our imagination.
Old 05-03-2011, 03:54 AM
We apply paste by brush as this is cheaper than spray. And quality with Cermark was bad, we have a lot of unnecessary marks. With Litoscript paste is better but still problem appeared.
Old 05-03-2011, 06:52 AM
And this problem is happened only on this tools. When we engrave on any other metal - stainles steel or routing bits or souvenir flask - everything if fine.
Old 05-03-2011, 07:12 AM
Rodney Gold is on a distinguished road
Some metals get stianed by the paste - the best way to apply is to airbrush it on , thinly.
Basically , the way to stop it staining is to get it on , laser and get it off VERY quickly , if you leave the Cerdec/Whatever on for long times waiting for it to dry and not washing off immediately will make the metal stain more. Never seen those dark marks with Cerdec tho , seen the other type of staining before
Old 05-03-2011, 07:28 AM
Thank's for advice. I am trying to clean metal as better as possible and will do tests later today. We try to maximum speed up process but result always the same
We use hairdryer to speed up drying - may be this is problem?
Old 05-03-2011, 10:17 AM
Well , it seems the metal reacts with the paste or something in the paste , almost like some stainless steel get water droplets that stain it. Cleaning the metal doesn't help much to avoid this. What we often do is cut a mask with some low tack paper based self adhesive and apply it , it leaves areas that are to be engraved cut out , then we apply the cerdec and engrave , it sort of limits the staining to only the marked areas and is not as noticeable.
Old 05-04-2011, 01:17 PM
Problem solved
Shear surface was washed with Fairy, dried, cleaned with vodka just to be 100% sure that there is no grease on surface, dried for 15 minutes to be sure that all cleaning liquids evaporated
AND
engraving was perfect!!
There was some traces of what you, Rodney, named "stained" but really not visible too much. Now awaiting order from customer
Paste for CO2 engraving on metal Litografa Laser Engraving & Cutting Machines 9 09-28-2011 06:29 AM
Need Help!- Who knows metal engraving? machinetime Engraving Machines 3 05-20-2010 12:56 AM
Engraving on metal compound $20 for one year Machinaria Laser Engraving & Cutting Machines 12 12-07-2009 07:39 PM
Engraving Metal? Trainhound DIY-CNC Router Table Machines 2 06-01-2008 08:52 PM
Metal engraving of firearms Rick D General CNC (Mill and Lathe) Control Software (NC) 3 02-17-2006 06:39 PM
