| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I had to etch a road on a big wood piece using my laserpro explorer 100 w (38" x 20") the other day, and I noticed that the straight line that I'm trying to etch or even cut is not coming out straight... It starts off straight at the origin and slants/slopes down the further out you go. the mirrors were all aligned by a laserpro tech a couple of weeks ago. I talked to my laserpro rep today and he said that it's probably one of the motors, so he's gonna send me an x and y motor so I can try them and see where the problem is from. Has anyone ever experienced anything like that? Do you think that the problem is from the x or y motors? Thanks |
| It's most likely dirty shaft encoders , the motors have a black cover on the end , remove the motor and gently gently pry the cover off off , look carefully to see how it comes off. You will see a disc that runs between a small optical reader....gently gently use a very soft brush and brush it off and perhaps unscrew the reader assembly and brush the optics clean , reassemble and put the black cover on - gently gently with EVERYTHING and then use masking tape to seal all the possible entrances for dust on the motor/cap interface. If its not that , then it could be a shot motor or it could be a belt pulley thats slipping on the motor shaft (unlikely it's that) |
| Need Help!- way to see the g code comands visualized line by line in Bobcad? | 777funk | BobCad-Cam | 3 | 04-07-2011 07:48 PM |
| How do I cut a sloped line | scheek | WoodWorking | 5 | 02-16-2011 05:49 PM |
| Need Help!- milling a straight line that follows a 3d path | chaz6966 | BobCad-Cam | 9 | 03-20-2009 10:28 AM |
| Aluminum extrusion as a straight-line ball slide | Charlye | Linear and Rotary Motion | 6 | 04-21-2006 09:41 AM |
| boss on a slanted surface | XXF | Haas Mills | 16 | 01-30-2006 10:29 PM |
